whats your timing set at with the TE1 & E1 diagnostic terminals jumped?
look for a MAP & IAT sensor, it was probably converted to BT ecu, look at the ecu for a p/n to find out also.
do you have and CEL's popping up? you should look into testing your TPS, MAP/IAT(if you have them), and water temp sensor for the ecu if the above are good.
20v silvertop hesitation/misfire
Re: 20v silvertop hesitation/misfire
My turd of an 86
20v swapped 86 write-up
My turd of an 86
I was having the EXACT same issues. Couldn't rev past 4k w/o hesistating/misfiring while apply approx 3/4 throttle. When I did go WOT it pulled hard but ran filthy rich. Took it to Deeps Garage. They said I've got dome vaccum leaks & wiring issues. In less than an hour they had it all patched up & running smooth. The car hauls ass now & will destroyed my buddies 16v Hi Comp w/ mods.
- VitriumGTS
NostalgicHiro20v wrote:I was having the EXACT same issues. Couldn't rev past 4k w/o hesistating/misfiring while apply approx 3/4 throttle. When I did go WOT it pulled hard but ran filthy rich. Took it to Deeps Garage. They said I've got dome vaccum leaks & wiring issues. In less than an hour they had it all patched up & running smooth. The car hauls ass now & will destroyed my buddies 16v Hi Comp w/ mods.
Where were the vacuum leaks? I'm having a hell of a time trying to track down my very intermittent hesitation problem too that happens in the same manner as yours but only very occasionally does it happen.
Shakotan, Oni-kyan & Hippari a-go-go baby!
They were some of the hoses in the back of the engine. There were 2 or 3 hoses I believe.
