Question on Digital Gauge Cluster (sensors)
yabaiani
Postby yabaiani » Tue Feb 20, 2024 1:44 pm
hello! does anyone have the part numbers for the digital oil pressure sensors, digital coolant sensors, needed for the digital gauge cluster to read properly? I already have a digital fuel sending unit, but need these ones if anyone has the part numbers.
Let me know. Thanks!
morgan
Re: Question on Digital Gauge Cluster (sensors)
Postby morgan » Thu Feb 22, 2024 7:09 am
the oil pressure sensor is just a dummy light style, on/off. most 90s toyotas will have them, including the 20v's. The coolant sensor, I forget what I sourced for my friend, ill look into that...i believe its the same as the oil, on/off, no actual gage reading?
My turd of an 86
20v swapped 86 write-up
yabaiani
Postby yabaiani » Mon Feb 26, 2024 7:39 pm
morgan wrote:the oil pressure sensor is just a dummy light style, on/off. most 90s toyotas will have them, including the 20v's. The coolant sensor, I forget what I sourced for my friend, ill look into that...i believe its the same as the oil, on/off, no actual gage reading?
Well let me know if you have more details. Anything is helpful
Jayrdee
Postby Jayrdee » Mon Mar 04, 2024 7:51 pm
Morgan is correct, for the oil pressure it's just a pressure switch; on/off. However the coolant sensor is just like the normal single-prong ones. This is on my GT-Apex Levin.
_____________________
instagram: @dacobjurbin
