Steering Rack U-joints AW11 vs AE86
mad_86
Postby mad_86 » Fri Dec 15, 2023 1:17 pm
I have a MR2 steering rack with MR2 u-joint in Ae86 , I was wondering if the Manuel ae86 U-joint are the same as MR2 aw11.
My u-joint is worn and has play. 10years since I had it.
OEM AW11 U-joints are discontinued.
OEM AE86 Manuel U-Joints are Not. $$$
Ae86 P/S are different - definitely won’t work. Lol
Any have a Manuel U-joint on a Aw11 steering rack??
davew7
Re: Steering Rack U-joints AW11 vs AE86
Postby davew7 » Sat Dec 16, 2023 4:13 am
I'm using a U-joint from a 1991 Camry, which is slightly longer than the stock AE86 joint, but there is enough spline on the steering column to fit it . I'm also using a stainless steel U-joint from Flaming River, that is about a 1/3 of the cost of a Toyota joint.
