Does anyone know of any decent replacement rear calipers for my Corolla GTS? Looked on rock auto and auto zone and see some just don’t know fitment…let me know!
Auto Zone
https://www.autozone.com/brakes-and-tra ... 565836_0_0
https://www.autozone.com/brakes-and-tra ... 565838_0_0
O Reilly Auto
https://www.oreillyauto.com/detail/c/br ... olla?pos=0
https://www.oreillyauto.com/detail/c/br ... olla?pos=1
Any replacement rear calipers for a GTS?
Re: Any replacement rear calipers for a GTS?
It is relatively easy to refurb your own if you can't find any. Biggest issue with calipers is corrosion behind the square section piston seal, the corrosion builds up and squeezes the seal onto the piston, the piston then fails to return. The same happens with the sliding pin, rust build up behind the rubber.
The rear calipers I sell have been used and tested. I always rebuilt mine but it reached a point that it had too much decay so I got these.
https://www.instagram.com/p/CV1mChpsDrr/
IG: profdens
IG Store: dsspeedshop
these fit, just no cable brackets.
https://www.ebay.com/itm/164769845860?h ... Swg3pgVHeq
My turd of an 86
20v swapped 86 write-up
My turd of an 86
