All,
After a decade or more of hiatus on the AE86 front, I am looking into getting back into the car.
Since I am well out of the loop, what ECU or tuning options are available for these cars nowadays?
Looking to stay N/A.
ECU/tuning
Re: ECU/tuning
Suggest you talk with Battle Garage about Haltech... https://shop.battlegarage-rs.com/collec ... nd_haltech
They should be able to hook you up with all you need.
Re: ECU/tuning
What does everyone do for a mild N/A setup?
I am not looking to go balls to the wall with the car...
Regardless of what is done to the Corolla, my daily will likely be significantly faster anyway.
Re: ECU/tuning
Sepheroth86 wrote:What does everyone do for a mild N/A setup?
what do you consider "mild"?
Stock a 4AGE makes about 112-115hp at the flywheel. Keeping stock management, stock cams, stock intake, and stock exhaust, I managed to make 120 whp (130-135 @ the flywheel). (dyno on left is measuring engine hp, dyno on right is measuring wheel hp)
Arguably... torque is more important in a 4AGE, and this engine makes significant gains over a completely stock 4AGE.
All it took was a set of smallport pistons, a carefully ported head, and a squish(quench) gap of .032"(.8mm)
Re: ECU/tuning
I suppose that I was thinking of using a smallport engine, and a set of cams with an aftermarket intake manifold and exhaust/header. This would have a static compression ratio in the mid 10:1 range, if I recall correctly.
In my experience with Honda B series engines over the years, one did not seem to make much more power once above 11:1 compression without using race fuel/e85.
Re: ECU/tuning
Sepheroth86 wrote:I suppose that I was thinking of using a smallport engine, and a set of cams with an aftermarket intake manifold and exhaust/header. This would have a static compression ratio in the mid 10:1 range, if I recall correctly.
Just using a smallport, but making the squish gap a bit tighter(.9mm instead of 1.2mm) by running the appropriate gasket will bump compression to nearly 10.7 (from 10.3). That will work well with a set of mild "264 type" cams. I would recommend a ported head, to further improve performance.
As far as aftermarket engine management - the lesson I learned - buying the ECU before finding a tuning ship is a lot like the old adage of putting the cart before the horse. My recommendation would be to shop tuning shops near you, learn their reputations. When you find a shop you trust, ask what they are familiar tuning on. This method makes your time tuning minimal because the shop knows the platform already - or, in other words, you don't have to pay the shop to learn how to tune the ECU you bought before hand........
Re: ECU/tuning
I'm going to try Speeduino.
Re: ECU/tuning
Actually been using the stock ecu with my turbo setup for more than 10 years.
Bigger Air Flow meter
Decapped Scion tc injectors_850cc
T3/T4 turbo
E-85
T3/T4 turbo
E-85
Re: ECU/tuning
as Jondee mentioned , Haltech by Battle Garage (Grant) , Monsoon Link by RNR Autosport, MS2PNP Gen2 from diyautotune.
those are quite familiar with the 4age 16V and 20V.
good luck
good luck
