First start up with ITBs
yabaiani
Postby yabaiani » Wed Jan 13, 2021 4:42 pm
Needs tuning, but wanted to share a quick video.
https://youtube.com/watch?v=wk4JdQ7u1sU&feature=share
Jeonsah
Re: First start up with ITBs
Postby Jeonsah » Thu Jan 14, 2021 4:33 am
Nice work! 4age all the way baby
Postby jondee86 » Fri Jan 15, 2021 2:13 am
Yeah... it's finally starting to come together :) Now to get it driving !!!
yabaiani
Postby yabaiani » Sat Jan 16, 2021 6:48 pm
Some more photos
Postby jondee86 » Sat Jan 16, 2021 10:01 pm
Very clean, very tidy, very nice... I like it a lot :) But you are going to have
to do something about that bottom radiator hose !!
yabaiani
Postby yabaiani » Sun Jan 17, 2021 6:55 am
jondee86 wrote:Very clean, very tidy, very nice... I like it a lot :) But you are going to have
Crap!!! You saw it...lol. I first bought the T3 kit which was blue and I bought a black set, but the bottom radiator hose didn’t fit, so had to go back to blue.
yabaiani
Postby yabaiani » Mon Jan 18, 2021 7:55 pm
Someone asked me for my build build sheet, and other than some placeholders for paint, and when I go to the dyno here it is:
Engine/Transmission:
JDM MAP 4AG 16V fully rebuilt by Republic Customs Engine in March 2020, Motor has also been Ported, Rough Cut and Gasket Match as well as Rotating Assembly has also been balanced
MRP AT Power Billet Throttle Body Kit
MRP 4AGE 16v COP Conversion Kit - Genuine 1NZ Bosch Coils
Turbosmart FPR800 Black with Gauge
Xspurt Injectors 550cc
Link G4+ Atom, 1/8" NPT Air Temp Sensor, 1/8" BSP Water Temp Sensor
AE86 Full RHD Loom to suit COPs
Pipercross C6003 Filter Box
Genuine Toyota 16v Redtop Pistons & Rings 81.5mm
Molnar Connecting Rods Early Type 40/20
Toda Camshafts 264 Duration, 7.9mm Lift Intake/Exhaust
Toda Valve Springs
Toda Timing Belt Kit
Toda Cam Gears
New/Replaced Every Gasket w/ Genuine Toyota Engine Gaskets (incl are the stem seals)
TRD 4AGE 16v 0.8mm Head Gasket
MRP 4AGE 16v +0.5mm Over Sized Stainless Steel Intake/Exhaust Performance Valves
ACL Race Main Bearings
ACL Thrust Washers
King Rod Bearing
MRP Main Reinforcement Caps
SuperTech Valve Guides
4AGE ARP Main Stud Kit
ARP 4AGE 16v Head Stud Kit
MRP 4AGE 16v 200mm AE86 Light Weight Flywheel
ARP Flywheel Bolts 4age
MRP Trigger Wheel Kit Suit RWD T3 Dual Pulley
Custom Oil Catch Can / Coolant Reservoir Tank Upgrade
AE86 World Vacuum Block
Techno Toy Tuning Crank Pulley, Water Pump, Alternator Pulley
New Water Pump
New Clutch Slave Cylinder
New Genuine Toyota Engine Motor Mounts
New Transmission Mount
New Battery (Relocated to hatch)
KOYO Radiator
KOYO High Pressure Radiator Cap
Techno Toy Tuning Radiator Hoses
Sard Low Temperature Thermostat
Fujitsubo Super EX Header Exhaust Manifold
Fujitsubo Legalis R S-Tail Exhaust Muffler
EXEDY Racing Stage 1 Organic Clutch Kit
ARD Low Resistance High Output Alternator
LSD & Tranny Flush w/ Redline 75w90 + Friction Modifier
Fully Rebuilt A/C & Heater w/ new A/C Compressor, Expansion Valve, remanufactured heater core, heater valve, heater cable, blower motor
New fuel tank
New fuel tank hanger / lines
New braided fuel lines
New Siemens 310lph fuel pump
New starter
New Oil Pump for 20v which is a 16v upgrade
New Clutch Fork
New Toyota Pilot / Spigot Bearing
New Clutch Release Bearing
Exterior:
Full Panda Paint Job completed in [date] by [insert name]
AE86 Kouki OEM Front and Rear Bumpers
AE86 Kouki Lip
AE86 Side Skirts
AE86 OEM Hood
AE86 OEM Mud Guards
AE86 OEM Grill
AE86 Trueno Rain Guards
AE86 Redline Tail Lights
AE86 OEM Hatch Spoiler
Techno Toy Tuning Aero Underpanel
Techno Toy Tuning Hatch Cover
Techno Toy Tuning Spare Tire Cover
New Side Mouldings
New Weather Stripping for Exterior
Interior:
Clean full interior
Digital Gauge Cluster Conversion w/ MPH Conversion, LEDs, Digital Oil Pressure, Digital Water Temp Pressure, Digital Fuel Sending Unit conversion
Kenwood Excelon DDX9906XR Head Unit
Hertz Dieci DCX100.3 4 Inch 2-Way Coaxial Speakers Front Speakers
Dynamat Equivalent Sound Deadening Throughout the Entire Car
Techno Toy Tuning Stainless Steel GTC Style Shift Knob
New Momo Wheel Trek R Leather 350mm Steering Wheel
New Interior dome light
New OEM Clock Bezel
New OEM Center console lid
New Genuine Toyota Upgraded “beefier” OEM door hinges
New Expert OZ 5pc Floor Mats
New OEM Radio Brackets
Royal Clover Key
New Weather Stripping for Interior
Suspension, Wheels & Brakes:
Greddy Coilovers in the front w/ Adjustable Greddy Springs/Struts Rear
CUSCO Adjustable Lateral Rod
CUSCO Tension Rod Bar
Okuyama Carbing Front Aluminum Strut Tower Bar Type II
CUSCO Front Sway Stabilizer Bar
CUSCO Rear Sway Stabilizer Bar
Techno Toy Tuning Lower Control Arms
Techno Toy Tuning Tension Control Rods
Techno Toy Tuning Big Brake Kit front w/ new rear rotors and steel lines
Megan Racing Front and Rear End Links
WORK Equip 03 Gold 15x6.5 +3 front w/ 15x7.0 -6 Rear Wheels
Yokohama Advan Fleva 195/50/15 for front and 205/50/15 rear
New OEM brake master cylinder
New OEM clutch master cylinder
New Flos Smaller Brake Booster
