ac delete
x1aO
ac delete
Postby x1aO » Wed Feb 20, 2019 5:44 pm
86 GTS anyone has an idea how the belt is tension if the ac compressor is removed. I know some 86 does not come with ac from factory, my still has power steering but no ac any idea?
aukword1
Re: ac delete
Postby aukword1 » Thu Feb 21, 2019 9:14 am
After searching the interwebs it looks like your best bet is to find someone selling the tensioner from a 4age that didn't have A/C. Also, you can try to modify the current tensioner to work without the ac compressor hooked up.
notnilc20
Re: ac delete
Postby notnilc20 » Sat Mar 02, 2019 6:51 am
x1aO wrote:86 GTS anyone has an idea how the belt is tension if the ac compressor is removed. I know some 86 does not come with ac from factory, my still has power steering but no ac any idea?
is it not like this?
tensioner should be on the power steering pump bracket... find a shorter belt. take a string and go around crank and tensioner pulley and ps pulley and measure length....then go to autozone and iirc they should be able to search the length of the belts and find one close...might have to be in mm's. it's what I did when I deleted ac on ny 190e back in the day.
notnilc20
Re: ac delete
Postby notnilc20 » Fri Mar 08, 2019 10:13 pm
guess you got it situated....good on you!
x1aO
Re: ac delete
Postby x1aO » Fri Mar 15, 2019 10:41 pm
thanks got it
