I purchased an 86 when I was in Japan, and had it sent over here. I got it for dirt cheep cause the frame was bent, Luckly I got a job working at a body shop when I got back to the states and earlier this week we pulled the frame back straight.
Some old before pictures
Here are some pictures!
First step is to bolt the car to the frame machine.
The amount of pressure put on the frame of the car is ridiculous. We were pulling and we actually pulled one of the claps off the pinch welds!
First pull was on the drivers side!
Needed to add some heat to help the frame get back to where it was!
After some heat and hammering we got it straight.
The passenger side need to be pulled over. So we put some tension pulling it foward.
And after pulling it somewhat forward we started pulling it to the right.
“Pose for a picture”
After we pulled it over, we measured and it wasn’t squared. so we pulled it down, and got it just right!
Nice and straight!
Looks much better then when it started! Later I will be Replacing the upper rad support. and then start busting all the rust and painting the bare metal. Car should be back together in the next 2 weeks!
[/quote]
