Oxygen Sensor help
dabes
Oxygen Sensor help
Postby dabes » Sat Jun 10, 2017 11:34 am
Long story short i have had my 86 for a while, it is on the stock USDM engine and ecu. I just found out that the line to my oxygen sensor is cut. the car runs fine, and there is no check engine light. In fact its probably been this way throughout its life of me owning it (from daily commutes in the past to track events)
That being said I feel the need to fix this issue now that I found that its not connected.
The issue is that the line is cut and I have no connector or anything on the harness that lets me know which line is supposed to connect to the o2.
Can someone show me where the line should come from? I have 2 black wires close to the driver side motor mount. also a few unplugged connector on the passenger side wiper motors.
I will take a few pictures and post them shorty. but if anyone might be able to show me a picture of where the o2 sensor wire would come from in the harness that would be a lot of help.
Thank you
dabes
Re: Oxygen Sensor help
Postby dabes » Mon Jun 12, 2017 12:12 pm
can anyone else me out?
shagymc
Postby shagymc » Mon Jun 12, 2017 12:53 pm
I'll get tech drawings offline when I get home tonight, but the best thing I would recommend is finding the pin in the ecu plug that comes from the O2 sensor, se your meter on continuity and test either of the two wires you suspect to be it. Ensure the plug is unplugged from the ecu when testing. I'd also check the ecu side of the wire to ground to make sure that it isn't grounded and giving erroneous readings on the meter. If that doesn't make sense PM me and I'll walk you through it.
Postby jondee86 » Mon Jun 12, 2017 2:43 pm
Maybe this helps ?
http://www.club4ag.com/forums/viewtopic.php?f=9&t=4049
