Where can i buy these?
Are the subframe/crossmember spacers nessicary?
Thanks
sr20 ae86 mounts ?
- HASport AE86
Re: sr20 ae86 mounts ?
JSPfab.com sells the kit
there is also a kit on ebay. the seller is in the US too
http://www.ebay.com/itm/Corolla-AE86-AE72-TE72-Silvia-sr20de-sr20det-sr20-Engine-Mount-Swap-Brackets-kit-/200894570178?_trksid=p2047675.m1850&_trkparms=aid%3D222001%26algo%3DSIC.CURRENT%26ao%3D1%26asc%3D11%26meid%3D5596570096530603727%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D190697416860%26
8-Eight_Six-6
I sell kits aswell. And you dont have to grind down that section of the block down, can remove the turbo assembly without having to pull the engine, and can use Megan screamer pipe with screamer part cut off and Apexi SR downpipe if you decide you want to save some money and not have a custom elbow/DP made. And my subframe spacers are way more beefy then those on eBay
