Is there any other compatible igniter?
arvin429
Postby arvin429 » Thu May 18, 2017 7:54 pm
I was wondering if the igniter in the AE86 is interchangeable with any other igniter. If I got an igniter from a N/A mr2, would the plugs plug right into my AE86 harness? If not is there any that would?
aukword1
Re: Is there any other compatible igniter?
Postby aukword1 » Fri May 19, 2017 7:09 am
What mr2 are we talking about? AW11 igniter should work.
arvin429
Postby arvin429 » Fri May 19, 2017 9:00 am
Yeah an mr2 or any other car
xslowpokex
Postby xslowpokex » Mon May 22, 2017 5:06 pm
Yea aw11 na is completely interchangeable, also the mr2 distributor cap and heatshield and a better design than the 86 one and its interchangeable, also you can buy a new aw11 dist from autozone pretty cheap and comes with heatshield, also make sure the igniter is actually bad cuz usually iis the dist. pickup coil that go bad especially if you rev high with headers and no heatshield, beats up the dist bad...
Users browsing this forum: Google Adsense [Bot], MSN [Bot] and 6 guests
