I need help identifying these connectors on my harnesses
arvin429
Postby arvin429 » Wed Apr 19, 2017 7:06 pm
I have two GTS dash harnesses. Each of them have some different connections.
Both have the connection for this relay which is on the passenger side
http://imgur.com/a/a1LsY
However only one harness has the connection for this relay. The harness that doesn't have this connection has no trace of it. It looks like it was never there. This relay is also by the passenger side
http://imgur.com/a/Pucn9
By the passenger Junction box there are two different cables. One is grey and the other yellow. What are they used for?
Grey:
http://imgur.com/a/L050G
http://imgur.com/a/pTGUQ
Yellow:
http://imgur.com/a/0Ht4Q
http://imgur.com/a/JLkXR
I have a GTS engine bay harness that seems to be missing connectors. I don't know if it is. It seems to have all the connectors to where it plugs into the driver side junction box, which is three. If there's more please let me know. On the passenger however, there's only one brown connector.
http://imgur.com/a/THpyj
http://imgur.com/a/0fJ4M
http://imgur.com/a/jzeCx
If anyone can help me that'll be great.
Thank You
liftedleaf_ae86
Re: I need help identifying these connectors on my harnesses
Postby liftedleaf_ae86 » Thu Apr 20, 2017 12:49 am
I'm fairly certain you have 1 GTS harness and 1 SR5 harness. The grey and yellow plugs are for the ECU systems, grey is Sr5 and yellow is GTS.
http://imgur.com/a/Pucn9 This is the charge lamp relay, only on Sr5. The GTS has a black fuel pump relay, OCR I think it's called. Not sure what the cut wires are, might be GTS specific but it looks similar to the SR5. If I'm right it's the top right on the passenger junction block.
http://imgur.com/a/Kl37h here's my sr5 for reference. Some of the wires are the same color.
The brown plug should go in the passenger block, top slot under the bracket. Hope I helped
arvin429
Postby arvin429 » Thu Apr 20, 2017 8:42 am
Oh okay. Thank you for your help
Users browsing this forum: No registered users and 15 guests
