GTS Gearbox Plate?
Kitsunami
GTS Gearbox Plate?
Postby Kitsunami » Tue Mar 21, 2017 1:19 pm
Hey all,
Anyone know if I can use my AW11 MR2 Tranny / Block Plate for my GTS swap? I believe the MR2 plate is cutoff about 3/4 the way down compared to the AE86 GTS plate... but I don't know for sure.
I know this is a GTS plate:
I'm going to venture a guess that I *could* use it, but that I should custom-fab the remaining portion to prevent things from getting into my bellhousing?
Any suggestions are appreciated. I don't see these plates for sale much, and they're certainly not addressed in FWD / RWD 4AGE engine conversion logs I've seen. If I can McGuyver something that'll do the job, I'd prefer to go that route rather than trying to source one.
aukword1
Re: GTS Gearbox Plate?
Postby aukword1 » Tue Mar 21, 2017 2:11 pm
I tried doing something similar with a 4agze plate. I believe the starter holes didn't match up or was on the opposite side. I don't see why you wouldn't be able to make it work with a little modification if it even needs it. Worst case scenario you can probably fab one out of sheet metal.
mad_86
Postby mad_86 » Wed Apr 12, 2017 3:15 pm
i think i have a spare GTS plate LMK if your intrested
