A Release Bearing Question and a Transmission question.
Posted: Wed Dec 14, 2016 7:30 pm
Hi. With my car in storage for the winter, I'm going about fixing some things. One question I have is if the release bearing should be spinning at all with the clutch pedal out. It spins slightly and makes a squealing noise. This is a new TOB by the way. I've tried adjusting free play, and right now, my pedal is as far out as it can be, but the TOB is still catching the clutch. Could this be a slave cylinder issue? It's like the pushrod is putting too much pressure on the fork, because I can push the fork towards the slave cylinder and the TOB will stop spinning. Maybe I didn't push in the TOB enough?
I'm going to check actual freeplay specifications tomorrow.
Also, my transmission whines in neutral, first, second, third and reverse. I had the gearbox rebuilt with all new bearings besides the center counter shaft bearing, but that one seems to be in good shape. Running Redline MT-90 at the moment, haven't tried shifting with it, but I think the cheapo Taiwanese synchros are junk. Bearings were all Nachi and Koyo. It was doing the same with Royal Purple. Sounds kinda like a supercharger or straight cut gears, and pitch increases with RPM. It's a T50 by the way.
The gears looked to be OK, not really damaged.
