Fitting 15x9.5j - 19, 15x10j -25 Watanabe on AE86
hachiroku
Postby hachiroku » Sun Feb 10, 2013 6:28 pm
Hi Club4AG,
I pulled the trigger on a set of RS Watanabe Type R:
15x9.5j - 19 on 205/50/15
15x10j -25 on 215/50/15
Pretty set on the tire size (as they came with the wheels), and I'm kind of timid about putting a 205 tire on a 10" wheel. (but hey, I might do it anyway) I'm performance oriented, but I have to say the Yamashita/Run Free 86's are ultimate style icons to me and I want to emulate the same kind of style and aesthetic. The car has plenty of power to break the 215's loose..
I'm trying to avoid putting flares on the car but don't know how feasible it is as in the rear I'll be installing a Supra rear end, making it an effective 15x10 -32 (I think). The fronts can be massaged to work with the metal fenders but it looks like the rears might be more difficult. Anyone stretch/pull their stock metal rear quarters enough to make such wide wheels to fit? I have some Jubiride copy fender flares in case I really mess up, but I'd like to see if someone who doesn't have a background in shaping metal (moi) can make these wheels fit with mere mm to spare.
Point me please!
gaijin_rokurunner
Re: Fitting 15x9.5j - 19, 15x10j -25 Watanabe on AE86
Postby gaijin_rokurunner » Mon Feb 11, 2013 10:46 am
Not going to fit in the rear buddy your going to need flares... Ive rolled my fenders pretty much to max to fit a 15x9 0 offset and the tires clear (195) but the rim edge is still about 1/4 past the fender edge...
mesh on my rolla
Postby mesh on my rolla » Mon Feb 11, 2013 7:06 pm
I didn't roll or pull anything. I'm on 15x9j -15 and the way around with 175/50R15! I have about and 1/2" if you don't mind. I'll try to post so pictures as soon as I figure out how... :D
Follow me on instagram = mesh_on_my_rolla
death_blossom
Postby death_blossom » Tue Feb 12, 2013 7:49 pm
mesh on my rolla wrote:I didn't roll or pull anything. I'm on 15x9j -15 and the way around with 175/50R15! I have about and 1/2" if you don't mind. I'll try to post so pictures as soon as I figure out how... :D
175/50r15? are you sure you didn't mean 195/50r15?
to the OP: with that wheel size and 205 tires, you'll need flares for sure.
omgitsfox
Postby omgitsfox » Wed Feb 13, 2013 1:21 pm
15x9 -15 Fits stock rear arches. Of course, you'll need to pull the crap out of them, but onelungderryl has them fitted with a 195/50/15. For a x10 in the back, pretty sure you'll need overfender/flare though.
RuizXIII
Postby RuizXIII » Wed Feb 13, 2013 8:58 pm
Hey, man. This is 15x10 0ET off an Aussie car.
I guess it should give you some idea?
It probably would stick out a good bit.
irony.cc
LongGrain
Postby LongGrain » Wed Feb 13, 2013 9:00 pm
just get run free rear flares and be a cool dude.
hachiroku
Postby hachiroku » Sat Mar 16, 2013 7:58 pm
I decided after buying flares to copy the profile of the Jubride flares and make metal ones with my own style added to it. Here's how it is so far.
It was actually not as hard as I imagined it to be. What made it easier was tracing an existing flare set on some 22 gauge sheetmetal, cutting and grinding and then welding to the stock body location where the OEM flare would start (obviously cut the old fender guards where needed). Lots more grinding, sanding, puttying and then painting to go.
KonaTrueno723
Postby KonaTrueno723 » Sat Mar 16, 2013 10:14 pm
Thats gonna turn out great hachiroku!
I too had taken that route & did my own chop/fab job to my rears couple yrs ago. I had to cut long slits to the inner rear wells & hammered it upwards,stitch welded it back together to a new outer lip. It was an involving process for me to getting it all straight, bodyworking then paint.. i really wished i had taken pics of this diy.
Right now it clears my work equip 01's 15x10-28 with a 225/50-15 tire (my street set), & it only rubs when i carry passengers, so i maybe looking into getting a set of rear flares, much like what skizzups runnin on his own car.
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
hachiroku
Postby hachiroku » Sun Mar 17, 2013 9:24 am
Hey man, try a 215 tire. I know it's a bit of a stretch but it works out well on my setup.
KonaTrueno723
Postby KonaTrueno723 » Sun Mar 17, 2013 12:01 pm
hachiroku wrote:Hey man, try a 215 tire. I know it's a bit of a stretch but it works out well on my setup.
Haha..I may try that man thanks! Yeah these 225's were freebies so can't complain. Got money goin to something else on my car at the moment
87 GTS Coupe
sqznby
Postby sqznby » Sun Mar 17, 2013 6:24 pm
hachi,
That looks great.
Do you still have that pattern traced out? Or did you only transfer it onto sheetmetal?
I'd love to make my own flares out fo steel, stronger and looks so much better.
hachiroku
Postby hachiroku » Thu Mar 21, 2013 11:14 pm
sqznby wrote:hachi,
That looks great.
I traced out a copy of a rear Jubiride flare and somewhat used it as a rough outline. brought out the angle grinder and went to town.
Here's how it is right now. I trimmed a little bit more of the arch for clearance and added a slightly elongated arch to let tire smoke vent outside of the wheel well to the back of the car. My buddy calls it "scalloped". Whatever, it's cool! Also mounted the kouki rear bumper, trimmed the tabs in the corners a bit and played some more with fitment.
Now onto the front fenders!
sqznby
Postby sqznby » Sat Mar 23, 2013 5:23 pm
Looks good man.
How much of the actual fender did you remove?
Thanks
RuizXIII
Postby RuizXIII » Mon Mar 25, 2013 2:26 pm
This thread just got really sweet! I like the DIY approach
Some more pics of your work would be cool, man.
irony.cc
sqznby
Postby sqznby » Sun May 19, 2013 2:59 pm
Any updates on some DIYer fenders?
Tibby
Postby Tibby » Tue Jun 11, 2013 10:48 pm
Im loving this diy thread im also looking into purchasing sum wats with the same measurements so im really looking forward to an update! Great job!
mesh on my rolla
Postby mesh on my rolla » Fri Jun 21, 2013 8:58 am
Yes I'm on 175/50 on a 9j. I've posted pictures here before but its not letting now. I can email you pictures if you like to see them. Just a little inner fender lip roll in the rear but other than that its stock body.
sqznby
Postby sqznby » Fri Jun 21, 2013 11:56 am
mesh could you send me some pics of your?
Thanks
mesh on my rolla
Postby mesh on my rolla » Fri Jun 21, 2013 2:38 pm
sqznby wrote:mesh could you send me some pics of your?
Thanks
This is at full lock... zero rubbing during hard braking or sliding :D
John H.
Postby John H. » Thu Jun 27, 2013 9:02 pm
Holy ISH! ^^^
Are those 15s or 14s?
Looks GREAT "mesh on my rolla"!
-John
Jimmee1990
Postby Jimmee1990 » Sat Jun 29, 2013 11:14 pm
And here I was thinking the point of wider wheels was wider tyres...
mesh on my rolla
Postby mesh on my rolla » Sun Jun 30, 2013 1:33 pm
John H. wrote:Holy ISH! ^^^
-John
Haha there 15" thank you sir
Jimmee1990 wrote:And here I was thinking the point of wider wheels was wider tyres...
Ummmmm "touche man"
Tibby
Postby Tibby » Mon Jul 08, 2013 9:12 am
hachiroku any updates?
Users browsing this forum: No registered users and 10 guests
