steering intermediate shaft question
Posted: Wed Feb 06, 2013 9:20 pm
by stephan2
Does anybody know were you can get the glue that's come on the intermediate shaft from factory from?? Iv been running the mk3 supra intermediate shaft with the aw11 steering rack and over time the glue stuff came off causing lots of play inbetween the intermediate shaft and the housing piece it sits in.. I tryed tac welding it as an alternative but the welds broke and I kinda get the feeling that welding it might be to unforgiving
Re: steering intermediate shaft question
Posted: Tue Feb 19, 2013 8:15 am
by stephan2
Posted: Tue Feb 19, 2013 11:57 am
by HASport AE86
Is this kevin bacon stephan? That stuff is rubber that is on the shaft. Just weld it more bro
Posted: Wed Feb 20, 2013 8:48 am
by Army Fork
Any sort of metal epoxy would work fine I'd imagine (metal bonding epoxy that is, not epoxy made of metal. If that even exists). JB weld would probably work better than fine.
Posted: Thu Feb 21, 2013 1:56 am
by stephan2
cool ... and yea its kevin bacon lol
Posted: Thu Feb 21, 2013 11:24 am
by ga_goosh
are you sure the play is comming from the i shaft and not the rack itself?
Posted: Tue Feb 26, 2013 1:57 am
by stephan2
It's for sure coming from the shaft.. You can pull on the shaft and look at the play as it happens
Posted: Tue Dec 02, 2014 2:06 am
by AE86 J.Spec
I have the same issue. Anyone have any new input on this topic? I would rather not weld it if there is another option.
Posted: Tue Dec 02, 2014 3:10 pm
by Glock30
You can try this stuff
http://multimedia.3m.com/mws/media/107695O/3mtm-super-fast-urethane-08609.pdf. I remember using it back in the Starion days for a motor mount or something. The urethane may even absorb some of the vibration.
Posted: Tue Dec 02, 2014 4:19 pm
by ryun84
Can someone describe the play in the manual steering from the above posts? I'm wondering if the play in my steering is from the same issue as described in this thread.
I also have a AW11 steering rack and a MK3 Supra intermediate shaft. When I'm driving straights the steering wheel can move/float left and right several degrees before finding resistance and changing the steering.
Posted: Tue Dec 02, 2014 4:51 pm
by Army Fork
I believe there's a bolt in your rack that determines preload between the pinion gear and the rack. If that loosens off, you could potentially have wide clearances that would give you that slop
Posted: Tue Dec 02, 2014 5:19 pm
by Glock30
ryun84 wrote:Can someone describe the play in the manual steering from the above posts? I'm wondering if the play in my steering is from the same issue as described in this thread.
For this you may want to check your rack mount bushings. I went to get an alignment once and the guy at the shop told me that the rack was loose. I didn't believe him till I felt it on the way home.
Posted: Tue Dec 02, 2014 5:53 pm
by ryun84
Army Fork wrote:I believe there's a bolt in your rack that determines preload between the pinion gear and the rack. If that loosens off, you could potentially have wide clearances that would give you that slop
Glock30 wrote:For this you may want to check your rack mount bushings. I went to get an alignment once and the guy at the shop told me that the rack was loose. I didn't believe him till I felt it on the way home.
Thanks for the advice! I will check them out.
Posted: Tue Dec 02, 2014 10:29 pm
by Resurrected
Check for possible play in the inner/outer tie rods as well. Inner tie rod play can be a little bit more difficult to see sometimes since the boot covers the joint.
