steering intermediate shaft question
stephan2
Postby stephan2 » Wed Feb 06, 2013 9:20 pm
Does anybody know were you can get the glue that's come on the intermediate shaft from factory from?? Iv been running the mk3 supra intermediate shaft with the aw11 steering rack and over time the glue stuff came off causing lots of play inbetween the intermediate shaft and the housing piece it sits in.. I tryed tac welding it as an alternative but the welds broke and I kinda get the feeling that welding it might be to unforgiving
stephan2
Re: steering intermediate shaft question
Postby stephan2 » Tue Feb 19, 2013 8:15 am
HASport AE86
Postby HASport AE86 » Tue Feb 19, 2013 11:57 am
Is this kevin bacon stephan? That stuff is rubber that is on the shaft. Just weld it more bro :lol:
Army Fork
Postby Army Fork » Wed Feb 20, 2013 8:48 am
Any sort of metal epoxy would work fine I'd imagine (metal bonding epoxy that is, not epoxy made of metal. If that even exists). JB weld would probably work better than fine.
1984 SR5-GTS 20V ST/BT coupe.
- Stance GR+ Coilovers
- Mishimoto Cooling
- T3 adjustable 4-bar, Panhard, traction brackets, tension rods
- T3 Short shift
- Manual rack conversion
- Blacktop electronics
stephan2
Postby stephan2 » Thu Feb 21, 2013 1:56 am
cool ... and yea its kevin bacon lol
ga_goosh
Postby ga_goosh » Thu Feb 21, 2013 11:24 am
are you sure the play is comming from the i shaft and not the rack itself?
I <3 my AE86
4AG Manual
AE86 FSM
stephan2
Postby stephan2 » Tue Feb 26, 2013 1:57 am
It's for sure coming from the shaft.. You can pull on the shaft and look at the play as it happens
AE86 J.Spec
Postby AE86 J.Spec » Tue Dec 02, 2014 2:06 am
I have the same issue. Anyone have any new input on this topic? I would rather not weld it if there is another option.
Glock30
Postby Glock30 » Tue Dec 02, 2014 3:10 pm
You can try this stuff http://multimedia.3m.com/mws/media/107695O/3mtm-super-fast-urethane-08609.pdf. I remember using it back in the Starion days for a motor mount or something. The urethane may even absorb some of the vibration.
1984 Toyota Corolla Sport SR5
1989 Ford Bronco Eddie Bauer
1968 Ford F250
Lots of 4AC info here: http://4ac-powered.forumotion.com/
ryun84
Postby ryun84 » Tue Dec 02, 2014 4:19 pm
Can someone describe the play in the manual steering from the above posts? I'm wondering if the play in my steering is from the same issue as described in this thread.
I also have a AW11 steering rack and a MK3 Supra intermediate shaft. When I'm driving straights the steering wheel can move/float left and right several degrees before finding resistance and changing the steering.
Army Fork
Postby Army Fork » Tue Dec 02, 2014 4:51 pm
I believe there's a bolt in your rack that determines preload between the pinion gear and the rack. If that loosens off, you could potentially have wide clearances that would give you that slop
- Mishimoto Cooling
- T3 Short shift
Glock30
Postby Glock30 » Tue Dec 02, 2014 5:19 pm
ryun84 wrote:Can someone describe the play in the manual steering from the above posts? I'm wondering if the play in my steering is from the same issue as described in this thread.
For this you may want to check your rack mount bushings. I went to get an alignment once and the guy at the shop told me that the rack was loose. I didn't believe him till I felt it on the way home.
1968 Ford F250
ryun84
Postby ryun84 » Tue Dec 02, 2014 5:53 pm
Army Fork wrote:I believe there's a bolt in your rack that determines preload between the pinion gear and the rack. If that loosens off, you could potentially have wide clearances that would give you that slop
Glock30 wrote:For this you may want to check your rack mount bushings. I went to get an alignment once and the guy at the shop told me that the rack was loose. I didn't believe him till I felt it on the way home.
Thanks for the advice! I will check them out.
Resurrected
Postby Resurrected » Tue Dec 02, 2014 10:29 pm
Check for possible play in the inner/outer tie rods as well. Inner tie rod play can be a little bit more difficult to see sometimes since the boot covers the joint.
L1 Master technician
Back from the grave!
