Gts driveshaft with sr5 rear end.
I have an sr5 rear end and the drive shaft looks to be gts because it's about an inch too short. Would i be able to use some kind of a spacer to fill in the gap between the rear end and driveshaft? I really don't want to buy an sr5 driveshaft right now b/c i plan on changing the rear end later down the line and it seems impossible to find a gts rear end. What would you do?
Re: Gts driveshaft with sr5 rear end.
Contact suspicious garage if you ever need one made. I might end up taking mine in soon since I'm having ujoint problems,. I'm trying the tricks I've had offered on this site first then if no luck I'm going to order one,. I'm sure if you just measure it all out they'll make it to your specs for about 300$
1976' Corolla/Levin TE37 3TC
