Wheel fitment with FC brakes
Nomnom83
Postby Nomnom83 » Sat May 21, 2016 4:51 pm
I'd thought I'd share what I've experienced with various wheels that I have and there clearance big brakes such as the rx-7 upgrade. From what I've learned offset and spoke shape play a big part in fitment, not so much wheel size or even rotor size. Basically since this is 2 more piston on the outside of the hub means you need generous spoke curvature for proper clearance. Which also sucks cause most old wheel designs ssr mk1,2,3 are pretty flat to the hub, so spacers are necessary.
Koenig rewinds 15x7 0
Fits but need to make sure you have a hub ring or the wheel will contact the caliper
Ssr Longchamp 14x6.5 +2
Will fit only with 12-15mm spacer
Plz share your experience with different wheels and sizes, I'm particularly interested if watanabe fit nice or not.
AE86Kai
Re: Wheel fitment with FC brakes
Postby AE86Kai » Sat May 21, 2016 8:14 pm
FC3S Calipers on ATS Classics 14x6.5 offset +9 (185/55R14)
PERFECT fitment with no spacers.
RS Watanabe 15x7 offset +14.5 w/5mm spacers (195/50R15)
aaronlee133
Postby aaronlee133 » Mon May 23, 2016 12:17 pm
Volk TE37s 14x7 0-offset. NO SPACERS REQUIRED AND FITS perfectly.
Users browsing this forum: No registered users and 25 guests
