I'd thought I'd share what I've experienced with various wheels that I have and there clearance big brakes such as the rx-7 upgrade. From what I've learned offset and spoke shape play a big part in fitment, not so much wheel size or even rotor size. Basically since this is 2 more piston on the outside of the hub means you need generous spoke curvature for proper clearance. Which also sucks cause most old wheel designs ssr mk1,2,3 are pretty flat to the hub, so spacers are necessary.
Koenig rewinds 15x7 0
Fits but need to make sure you have a hub ring or the wheel will contact the caliper
Ssr Longchamp 14x6.5 +2
Will fit only with 12-15mm spacer
Plz share your experience with different wheels and sizes, I'm particularly interested if watanabe fit nice or not.
Wheel fitment with FC brakes
aaronlee133
Re: Wheel fitment with FC brakes
Volk TE37s 14x7 0-offset. NO SPACERS REQUIRED AND FITS perfectly.
