gts fuel wire gauge
S_p_R_i_T_e
gts fuel wire gauge
Postby S_p_R_i_T_e » Sun Jan 03, 2016 6:17 pm
Would like to know what size gauge does the gts fuel tank use. This would be the one that runs from front to tank. It will be converting from sr5 to gts and if I'd remember correctly there was a post on the old site to change gauge of wire since sr5 is smaller than gts. Thanks in advance
davew7
Re: gts fuel wire gauge
Postby davew7 » Mon Jan 04, 2016 5:34 am
You should be OK with 16 gauge wire, if the run is longer the 15' use 14 gauge. Dave W7
S_p_R_i_T_e
Postby S_p_R_i_T_e » Mon Jan 04, 2016 2:57 pm
Sounds good thanks
