ae86 gts.harness/motor swap question
S13562
Postby S13562 » Wed Sep 09, 2015 10:20 pm
sup guys
i have an ae86 gts and i recently sold the 4age/ecu/ wiring harness
it is an original gts and i am currently looking for a new swap.i am looking to install an sr20det and was wondering if i need the original gts harness or if i can use the sr20det harness and ecu.
im guessing that i do need the ae86 harness if someone can please help clarify
thanks in advance
phanist
Re: ae86 gts.harness/motor swap question
Postby phanist » Thu Sep 10, 2015 2:45 am
I would u will only need the oem gts 4ag engine harness for the plug connector if you plan on using some of the 4ag exterior parts like alternator and ps and ac etc.... Other wise u use the what ever engine u swaping harness and mod both wire into one......
Hope that help
aceforever
Postby aceforever » Thu Sep 10, 2015 9:22 am
You should be fine. The main thing is to keep some of the wiring for interfacing with the ae86 tachometer, oil pressure, coolant temp.
Other than that, you'll be using the sr20 wiring.
S13562
Postby S13562 » Sat Sep 26, 2015 5:50 pm
ok thanks guys i thought so... but what about the gts fuse box.???
