So I got this car as a project. I was told that it just needed a fuel pump. The car cranks, turns over and starts but then dies shortly thereafter and I've had a car that did the same in the past that ended up needing a fuel pump. So in my quest to fix this car I came onto a surprise, this car NEEDED MORE than a fuel pump. Pic of the tank dropped and what came out of it:
So I took the tank to a radiator shop to clean out all the gunk and rust that was in there and I ordered myself a new fuel pump. I cleaned up the fuel pump bracket and sender bracket that was caked in rust and put everything back together, but the results are the same.
Click this pic so you can see a video of the problem.
I noticed that the EFI relay was extremely hot, so I could have an issue with that and will swap it out with a known working relay. I also read on some other forums and threads that there is a specific ground wire that needs to be hooked up (not sure if to a sensor or the engine block) that makes the fuel pump function with the key in the ON position, maybe someone can clarify this for me.
Along with swapping out the EFI relay I will also get a new fuel filter and try using starter fluid to see if the car stays on or not. Is there anything else I should be checking or anyone can lead me in the right direction? I also have a spare MAF and both give me the same result, doesn't stay turned on.
