Ae86 Front brake rotor lug pattern?
Doing an rx7 front brake swap and getting my rotors redrilled but need to know the hole pattern of the ae86 front hub where the rotor will bolt up, any help is much appreciated, thanks!
Re: Ae86 Front brake rotor lug pattern?
The stock AE86 lug pattern is 114.3 x 4
Calikid wrote:Doing an rx7 front brake swap and getting my rotors redrilled but need to know the hole pattern of the ae86 front hub where the rotor will bolt up, any help is much appreciated, thanks!
4x114.3 lugs, but not rotors.
Stock front rotors are 4x87 and mount behind the hubs. The link below should help.
Per Centric.
http://centriccatalog.com/Inquiry/viewD ... &ic=2&i=1&
Have a pair of them sitting in front of me. (2 pairs, actually. lol) No direct experience with the 15x swap but if you're refuelling o stock mount the new rotors, it'll help.
Nick.
I've heard of people using mini cooper rotors for the FC Brake set-up.. might save you time from drilling?
