Electric Fan - 4ac Thermo Switch to trigger E fan in 4AG
Posted: Tue Jul 14, 2015 5:59 pm
For those of you looking to do this, there are a few diagrams floating around and having just done this mod over the weekend, i thought i'd save some people the frustration of which is the proper diagram.
If you buy/pull the thermo switch & thermo housing from a 4ac, chances are you got an "always closed" switch. When the car gets up to temp, the switch breaks the circuit and triggers the fan to turn on (this is the single wire 4ac switch most of you know about). The only way this will work properly is to run it with 2 SPDT relays, as shown in this link:
http://www.redlinedaily.com/automotive. ... an_install
i tried to use 2 other diagrams (i won't post them to avoid confusion) and the fans would either stay on with ignition or never turn on. Remember this is just a reference, please double check your wiring, information and always disconnect the battery when you're working on the electrical system in your car.
