Is CXRacing 20v Exhaust any good?
vashachiroku
Postby vashachiroku » Thu Jun 25, 2015 6:40 am
Searched the forums didn't see a feedback or any type of thread. I was thinking about buying this for my swap.
http://www.cxracing.com/mm5/merchant.mv ... Quantity=1
Any feedback on the product? I would like to order today.
Lowtekk
Re: Is CXRacing 20v Exhaust any good?
Postby Lowtekk » Thu Jun 25, 2015 12:13 pm
Unless you're making your own downpipe, you should spring for the 2pc header. No idea how the quality is, but they sell them with and without the downpipes.
http://www.cxracing.com/mm5/merchant.mv ... B-VCLM-250
Garage7RP
Postby Garage7RP » Thu Jun 25, 2015 6:38 pm
The design looks good but the piping configuration is wrong or not efficient. As you can see in the picture, exhaust pipe #1 and #2 are together, and #3 + #4 are together. The ideal piping configuration in a 4-2-1 system is pipes #1+#4 and #2+#3 should be together. Hope this helps your decision.
alavelle12
Postby alavelle12 » Thu Jun 25, 2015 9:09 pm
I bought just the header, wish I would have bought it with the downpipe. It's alright, not very good flow off of the flange, welds look okay, but can't expect much from a cheap header. It'll do the job for now, that's about all I can say about it. It'll work as a starter
Oggy
Postby Oggy » Fri Jun 26, 2015 8:07 pm
Since you have one, can you confirm which cylinders are paired together? Everyone just seems to be going by the same few pictures, so I want to hear from someone that has it in front of them.
vashachiroku
Postby vashachiroku » Sat Jun 27, 2015 5:22 am
I bought it since trying to finish up my swap let everyone know what I think as I ordered the cat back. I really wanted to get the Toda one, but since my car is only used a few times a year so cant justify the price tag. If I drove the car more it wouldn't be a problem.
http://www.importparts.com/toda-racing- ... iles-only/
Oggy
Postby Oggy » Sun Jun 28, 2015 2:28 pm
TODA is also only for RHD.
vashachiroku
Postby vashachiroku » Wed Aug 05, 2015 7:01 pm
Mine is RHD =)
This CXRacing with downpipe didn't line up to the cat, it was way off. I ended up cutting the down pipe and re-welding the flange to line up with the OEM cat. Very annoying something so expensive doesn't have proper alignment. It also didn't fit the 20v BT with a water line block off plate either, so had to cut around the bolt too.
Postby MisterJerk » Thu Aug 06, 2015 8:39 am
Could you post a pic of the header you got, especially the 4-2-1 parts? So we can see which cylinders are paired together.
Thanks!
vashachiroku
Postby vashachiroku » Sat Aug 08, 2015 9:38 am
Give me some time its at the tuning shop now waiting for my standalone to come in, but more than happy too!
