5zigen header
ultradx
5zigen header
Postby ultradx » Tue Feb 24, 2015 4:47 am
I will the 5zigen header fit our american ae86?
Clouds
Re: 5zigen header
Postby Clouds » Tue Feb 24, 2015 9:15 am
Depends on what trim level you have. Do you have a GT-S or SR-5?
Second, what model is the header for?
Come back and tell a little bit more about what you have and what you're looking at. :)
ultradx
Re: 5zigen header
Postby ultradx » Tue Feb 24, 2015 1:50 pm
It a 86 corolla gts hatch and I will find out what is the spec on the header.
ultradx
Re: 5zigen header
Postby ultradx » Tue Feb 24, 2015 8:13 pm
Specs
SUS304 stainless steel, tig-welded, laser cut flange, 4-2-1 headers. Runner pipes are 42.7mm diameter, outlet is 50.8mm.
Part # BT0EX05-P
Clouds
Re: 5zigen header
Postby Clouds » Wed Feb 25, 2015 6:52 am
It should fit as the 5zigen website says that it is for the AE86 and that is for the 4AGE. This means that it can only be 16v and that it should fit all 4AGE Corollas.
Someone, correct me if I am wrong, but I think that you should just go ahead and get the headers.
jdm86gtz
Re: 5zigen header
Postby jdm86gtz » Wed Feb 25, 2015 7:28 am
Unless they are only for RHD cars like most headers available from Japan.
Clouds
Re: 5zigen header
Postby Clouds » Wed Feb 25, 2015 9:12 am
jdm86gtz wrote:Unless they are only for RHD cars like most headers available from Japan.
Checked again and the header is for the same side as a US 4AG. :)
Re: 5zigen header
Postby Deuce Cam » Wed Feb 25, 2015 9:44 am
FYI most - if not all - Japanese market rwd 4age manifolds won't fit a left hand drive vehicle. Lhd models have a steering rack in the way of the exhaust and rhd doesn't. If the manufacturer doesn't specify that it will fit lhd assume it won't.
Clouds
Re: 5zigen header
Postby Clouds » Wed Feb 25, 2015 9:48 am
Deuce Cam wrote:FYI the vast majority of Japanese market rwd 4age manifolds won't fit a left hand drive vehicle. Lhd models have a steering rack in the way that rhd models don't have to deal with. If the manufacturer doesn't specify that it will fit lhd assume it won't.
That's helpful to know.
@ultradx: Do you really need the 5zigen header specifically? Why don't you try another search, man?
ultradx
Re: 5zigen header
Postby ultradx » Wed Feb 25, 2015 8:30 pm
Thanks for the useful information, I will try to locate a vibrant header. I was hoping somebody had experience with it. the header is $830 shipped.
Re: 5zigen header
Postby MisterJerk » Fri Feb 27, 2015 5:46 am
You will not find a vibrant header new. Power craft japan makes a LHD header.
If you are at the 800 dollar range for a header and you are looking for quality, you might as well save up the rest and get a JSP.
