Club I need help ASAP!
Zenki85
Postby Zenki85 » Sat Jan 26, 2013 12:09 pm
Here's my situation. Let me first start it off with a picture
So here are the front coils for a ae86.
I took apart the old "stock" struts taken off the rotors and I was putting the break shield on. Then I notice the holes did not line up. So I thought maybe Its the wrong side so I took the other one apart and I was the same.
The holes for the shield on the strut is shorter than the original. And only one of the bolts on the right would bolt up.
My question is. Did I get the wrong spindle on my megan or is my "stock" suspension weren't really stock? thank you.
TEAM 'CLASSIC
A 'CLASSICALIFORNIACAR
Jeonsah
Re: Club I need help ASAP!
Postby Jeonsah » Sat Jan 26, 2013 8:04 pm
You either have the wrong spindle/strut setup or you making a simple orientation mistake(most likely this one).
Make sure you have the correct spindle on the correct side of the car and for reference the calipers on the front spindles mount on the side closest to the front bumper. By looking at this picture:
http://imageshack.us/photo/my-images/21 ... 4.jpg/sr=1
It seems the bolt patter is pretty close, if not the same, as to what you have in your picture. In the picture the left assembly is the passenger side, and the right one is the driver side. Your calipers bracket/calipers will mount where the dust shield is open.
Im sure you just need to look at it again. Hope this helps
Vic
Zenki85
Postby Zenki85 » Sun Jan 27, 2013 11:49 am
I believe I got the wrong spindles then. The measurements from my original then to the Megan's are completely off
TEAM 'CLASSIC
KonaTrueno723
Postby KonaTrueno723 » Sun Jan 27, 2013 12:05 pm
Zenki85 wrote:I believe I got the wrong spindles then. The measurements from my original then to the Megan's are completely off
zenki85..I'd put in a call tomarrow to the supplier to get answers. Somethings not right!
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
Zenki85
Postby Zenki85 » Sun Jan 27, 2013 1:12 pm
My stock
TEAM 'CLASSIC
Zenki85
Postby Zenki85 » Sun Jan 27, 2013 1:13 pm
Yes. Thank you. Here are pictures above
TEAM 'CLASSIC
KonaTrueno723
Postby KonaTrueno723 » Sun Jan 27, 2013 11:47 pm
Oh yeah..huge difference. The Megan's sure looks similar to the Cressida flange..I may be wrong
87 GTS Coupe
assassin10000
Postby assassin10000 » Mon Jan 28, 2013 11:22 pm
You didn't have stock struts.
Here's a pic of Greddy's.
Andrew
