Megan coils help.
Zenki85
Megan coils help.
Postby Zenki85 » Fri Jan 25, 2013 7:03 pm
Soooo I just picked up my coilovers. And I put the rear in but my problem now is that I can't seem to tighten up the top bolt without the shock moving with it. Tried holdin the shock. And tried holding the shock and using a impact wrench
TEAM 'CLASSIC
A 'CLASSICALIFORNIACAR
Adriansadriano@yahoo.com - email
GreenLantern
Re: Megan coils help.
Postby GreenLantern » Fri Jan 25, 2013 8:03 pm
What top "bolt"? There should be two nuts up top in rear from inside the trunk and one bolt holding the bottom of the strut.
Jeonsah
Postby Jeonsah » Fri Jan 25, 2013 8:07 pm
I would jack up the car with the rear drooping a bit. Then I would undo the bottom bolts of each strut. Then try tightening the top nut of each strut. I think you just gotta finangle with it and it probably is just in a pickle haha.
Also- on my car there are 2 nuts at the top of the strut. One is to hold in place while you tighten the nut on top of it. Mabe this is your issue.
Good luck
Vic
Zenki85
Postby Zenki85 » Fri Jan 25, 2013 10:00 pm
Thank you for input! I was able to get it done. Thanks club!
TEAM 'CLASSIC
Users browsing this forum: No registered users and 11 guests
