How to remove USDM front and rear bumpers
E_Money
Postby E_Money » Thu Jan 24, 2013 4:40 pm
Sorry for the newbie question
gzus13
Re: How to remove USDM front and rear bumpers
Postby gzus13 » Thu Jan 24, 2013 6:30 pm
The front bumper is held on by two bolts (either 17 or 19mm head) just inside of and below the turn signals. There are also four other bolts going through the frame rails behind the bumper and below the headlights. Wind the headlights up and remove the plastic panel underneath. The bolts are under there. Use a wrench on the underside of the frame rail.
The rear bumper is held on by four of the same size bolts threaded into the frame rails. Pull up the carpet and there are four rubber covers with the bolts underneath.
Hope this helps.
88 AE92 Corolla DX, 86 AE86 Corolla GT-S, 73 TE21 Corolla Deluxe
Psalm 91, 2 Timothy 1: 9-10, Ephesians 2: 8-10
http://www.superhachi.com
E_Money
Postby E_Money » Thu Jan 24, 2013 7:12 pm
gzus13 wrote:The front bumper is held on by two bolts (either 17 or 19mm head) just inside of and below the turn signals. There are also four other bolts going through the frame rails behind the bumper and below the headlights. Wind the headlights up and remove the plastic panel underneath. The bolts are under there. Use a wrench on the underside of the frame rail.
Hope this helps.
thanks I'll try and find it. Should I have the car jacked?
Jeonsah
Postby Jeonsah » Thu Jan 24, 2013 7:22 pm
you'll be fine without the car jacked up
death_blossom
Postby death_blossom » Thu Jan 24, 2013 7:24 pm
no, you shouldn't need the car jacked up to remove the bumpers.
but be careful of removing these bolts. they' might be seized on and will take a bit of muscle to remove them.
E_Money
Postby E_Money » Thu Jan 24, 2013 8:15 pm
Oh I got plenty of muscles ;] US Air Force muscles.. haha jk jk. thanks for all the help guys I will do it right now and if I have questions ill go right back to this thread.
E_Money
Postby E_Money » Thu Jan 24, 2013 9:02 pm
okay Im a failure I couldnt find these bolts. I guess Im just mechanically inclined
Flipp
Postby Flipp » Thu Jan 24, 2013 11:46 pm
well that just tell me your not in maintenance. haha
if your still having trouble, ill see about finding the diagram in the FSM and posting it on here for you. i work mids so it wont be til later on tomorrow today
"Life happens at the corners"
E_Money
Postby E_Money » Fri Jan 25, 2013 5:34 am
Flipp wrote:well that just tell me your not in maintenance. haha
I work maintenance just not vehicle maintenance. I also didnt have that much time to go spotting these bolts. Ill try again later today
Jeonsah
Postby Jeonsah » Fri Jan 25, 2013 8:03 am
Start with the rear bumper. Here is how to locate the bolts:
1. Open your Hatch/Trunk
2. Remove the carpet
3. There are 4 black plastic caps covering 4 holes - Remove these
4. These are the 4 bolts to remove the bumper
Before undoing these bolts. Make sure you undo all the bumper bolts on the outside of the car. They should be on the sides of the car by the rear tires. If you look under the car, there are like 20 10mm bolts on the bumper - Dont remove these, these just keep the plastic painted cover over the metal beam that is your rear bumper!
For the front of the car its basically the same:
1. In the area where the hood latch, oil cooler, ac stuff resides. the bumper has 4 big bolts like the rear bumper. They're attached to the chassis of the car.
Good luck
Vic
E_Money
Postby E_Money » Fri Jan 25, 2013 10:41 am
Jeonsah wrote:Start with the rear bumper. Here is how to locate the bolts:
Good luck
Vic
thanks for the info I will get it done.
Users browsing this forum: Majestic-12 [Bot] and 6 guests
