Taking off shocks
hachikuku71
Taking off shocks
Postby hachikuku71 » Sun Nov 30, 2014 2:23 pm
Hi there! I'm trying to take off the shocks from the front struts & I'm stuck. I have the spring compressed already, what's next? Please advise & thank you.
KC
marin86
Re: Taking off shocks
Postby marin86 » Sun Nov 30, 2014 3:21 pm
If you have the spring compressed you should be able to take top hat off then have access to strut tube nut?
hachikuku71
Postby hachikuku71 » Sun Nov 30, 2014 3:30 pm
I do see the strut tube nut, but I don't have an angled open end wrench. That's where I got stuck.
Postby jondee86 » Sun Nov 30, 2014 3:33 pm
There is a good writeup here...
http://japanesenostalgiccar.com/2009/07/02/jnc-wagon-tokico-shocks-install/
Not an AE86 but close enough :)
Only comment I would add is that you might find it easier to crack the
main spindle nut loose while the weight of the car is still on the strut.
Don't move it more than a turn or two... just enough to make it easier
to shift once the strut is out of the car.
Postby jondee86 » Sun Nov 30, 2014 3:48 pm
And another one with detailed pics...
http://betwixtfantasyandreality.weebly.com/blog/ae86-front-strut-cartridge
Note that you don't have to take the hubs off the stub axles :-P
allencr
Postby allencr » Sun Nov 30, 2014 7:25 pm
IF the shock's instructions don't state it, put some oil in the tube to conduct heat away from the new insert to the strut to atmosphere.
