Cost of doing a 20v swap?
Posted: Mon Nov 24, 2014 7:10 pm
by BrianZ
just wondering how much can it be done.
I've seen just the 20v motor going for 600~700 bucks on ebay.
Wondering how much in labors and other parts gonna cost.
Re: Cost of doing a 20v swap?
Posted: Tue Nov 25, 2014 12:48 am
by benjamingon
if your doing it urself it can vary depending on how deep you want to go. Are you going to rebuild ur motor? or add other parts? cams? etc? Call up RSPECauto if your in so cal 818.806.8486
rspecauto@gmail.com, they are doing my buddy Charles car at the moment they will answer your questions or pm charles ---- Mr.Fujiwara is his sn.
Posted: Tue Nov 25, 2014 7:33 am
by BrianZ
benjamingon wrote:if your doing it urself it can vary depending on how deep you want to go. Are you going to rebuild ur motor? or add other parts? cams? etc? Call up RSPECauto if your in so cal 818.806.8486
Haven't given much of a thought tho, well the bottom line is getting the 16v out and putting the 20v in make it runs and drives..
Posted: Tue Nov 25, 2014 1:32 pm
by InitialB
I'm currently in the process of doing the 20v swap. Here's what I've spent so far getting the car together without including fuel cell, links , etc.
BT 20v (came with RS Chita dizzy cap and spigot bearing in place) - $900
Tec Art's trumpets - $330
SS Works waterline - $660
Honda D17 COPs - $20
Engine harness/ECU (Did the wiring myself) - $220 ($500 pre-made by Tweakd)
Tercel throttle cable - free99
Exhaust manifold - $500
That's more or less what you're looking at.
Posted: Tue Nov 25, 2014 2:30 pm
by saiGone
It's also a good time to go new engine mounts/ clutch
Posted: Tue Nov 25, 2014 2:45 pm
by InitialB
saiGone wrote:It's also a good time to go new engine mounts/ clutch
Also this^
