Cost of doing a 20v swap?
BrianZ
Postby BrianZ » Mon Nov 24, 2014 7:10 pm
just wondering how much can it be done.
I've seen just the 20v motor going for 600~700 bucks on ebay.
Wondering how much in labors and other parts gonna cost.
benjamingon
Re: Cost of doing a 20v swap?
Postby benjamingon » Tue Nov 25, 2014 12:48 am
if your doing it urself it can vary depending on how deep you want to go. Are you going to rebuild ur motor? or add other parts? cams? etc? Call up RSPECauto if your in so cal 818.806.8486 rspecauto@gmail.com, they are doing my buddy Charles car at the moment they will answer your questions or pm charles ---- Mr.Fujiwara is his sn.
BrianZ
Postby BrianZ » Tue Nov 25, 2014 7:33 am
benjamingon wrote:if your doing it urself it can vary depending on how deep you want to go. Are you going to rebuild ur motor? or add other parts? cams? etc? Call up RSPECauto if your in so cal 818.806.8486 rspecauto@gmail.com, they are doing my buddy Charles car at the moment they will answer your questions or pm charles ---- Mr.Fujiwara is his sn.
Haven't given much of a thought tho, well the bottom line is getting the 16v out and putting the 20v in make it runs and drives..
InitialB
Postby InitialB » Tue Nov 25, 2014 1:32 pm
I'm currently in the process of doing the 20v swap. Here's what I've spent so far getting the car together without including fuel cell, links , etc.
BT 20v (came with RS Chita dizzy cap and spigot bearing in place) - $900
Tec Art's trumpets - $330
SS Works waterline - $660
Honda D17 COPs - $20
Engine harness/ECU (Did the wiring myself) - $220 ($500 pre-made by Tweakd)
Tercel throttle cable - free99
Exhaust manifold - $500
That's more or less what you're looking at.
saiGone
Postby saiGone » Tue Nov 25, 2014 2:30 pm
It's also a good time to go new engine mounts/ clutch
InitialB
Postby InitialB » Tue Nov 25, 2014 2:45 pm
saiGone wrote:It's also a good time to go new engine mounts/ clutch
Also this^
Users browsing this forum: No registered users and 21 guests
