thanks!!
A/C Condenser
A/C Condenser
aloha, trying to stitch back my a/c conditioning system, running a MAP 4ag motor. i'm only Missing the condenser and the lines coming off the dryer. Anyone know if i can use a condenser and the lines off the dryer from other toyota models? toyota over stock has some listings but not all the lines.
thanks!!
thanks!!
Re: A/C Condenser
Most anything can be made to fit, any Toyota or other car, but the Toyota will probably be closest, that's all, as they like to not reinvent the wheel, only just change it a bit to F U Up.
Re: A/C Condenser
This would be something I would look up on www.toyodiy.com or just go down to a Toyota dealership and they can check if the same parts were used in other models. Good luck.
