Here's a video of the problem:
http://www.youtube.com/watch?v=XTQxiMLs ... e=youtu.be
I removed the center cover of the control box and removed the the screw inside. I removed the screw and there was no spring in there, just the screw and the washer. Is the missing spring causing this or could the sunroof getting stuck be something else? Where can I get a new spring at?
AE86 Sunroof problem ***SOLVED***
Re: AE86 Sunroof problem... Video included.
So, I figured out what the problem was. Some how the sunroof's stoppers got caught under the wind deflector, causing the sunroof to only open just to open a bit and then get stuck. All I needed to do was remove the sunroof cover, remove the 2 bolts that held both stoppers, open the sunroof, and then move the stoppers above the wind deflector.
