HID problem
HID problem
Just installed an HID kit in my car, but when I turn my headlights on, only the smaller bulb that's under the actual HID bulb turns on, which is the high beam i believe, that actual HID longer bulb doesn't turn on. I tried flipping my high beam switch but nothing happens. Any ideas on why it might be doing this? Also I tried flipping the plug on the ballast reverse, but still nothing.
Re: HID problem
try running a separate ground wire the oem wires are not right for hid conversions. mine did the same thing and a quick wire to the chassis did it for me.
Re: HID problem
Related question:
Is the 12V+ wire to the headlights on a relay circuit from the factory? Or is it necessary to run relays to the battery connecting them to the ballasts when the headlight switch is turned on?
2001 Carbon Black e39 M5
