air conditioning help
when I turn on the fan, and press the a/c button, the fan blows but the a/c compressor clutch is not engaging. I checked the fuse and it is ok. When I hotwire directly to the compressor, it runs but the vvis(idle up) wont engage, no signal. Any idea would be appreciated
Re: air conditioning help
Is your system charged with enough refrigerent? There is a low pressure switch that I believe doesn't allow the clutch to engage if the pressure is too low. Check the wiring diagram.
http://files.aeu86.org/manuals/ewd-ae86 ... parrot.pdf
