Im trying to finally finish my build and this damn MSPNP from Megasquirt wont start my car Im kinda confused as to how to set base timing? And all this trigger angle stuff. Am i supposed to do this all before i even start the car?
My setup: T25, CX Racing Manifold and IC Kit, 440cc Injectors, MAP Setup, GM IAT.
I load the Turbo startup map, convert it to MAP, Jumper my fuel pump. Vehicle is getting spark, and Fuel. It just does not start. I am at a loss and am looking for someone that has had success running a 4AGE off the MSPNP
MSPNP2 Succes stories?
- ToeKnee805
Re: MSPNP2 Succes stories?
What ignition system are you using ?
A spark is a spark is a spark, useless unless it is at the right time.
- ToeKnee805
stock dizzy
and yours is a USDM car ?
My memory of the mspnp is that it has pinouts for USDM cars only.
you may have already seen this:
http://www.diyautotune.com/tech_article ... rt_122.htm
- ToeKnee805
yeah usdm. that writeup is for MSnS. mines MSPNP. fully plug n play to my stock harness
is your timing belt aligned correctly?
- ToeKnee805
yeah i checked and triple checked and quadruple checked
how about the distributor alignment?
- ToeKnee805
i was off a tooth on the dizzy and i think i got it right now. Its a little tricky to get these dizzys to line up! I justm ostly need help in knowing how to correctly set base timing, and if i do it before or after i start this thing
- ToeKnee805
After a few emails back and forth with Russ from DIYAutoTune i found the problem. When i loaded the bas emap, it didnt have injector/fuel values like i thought it would. I told the map i had a 1600cc motor, and 440cc injectors. Played with the dizzy a lil bit and vroom vroom.
ooohhh yyyeeeaahhh!!!
