Another 4AG Problem
knockoutcold
Another 4AG Problem
Postby knockoutcold » Wed May 14, 2014 3:37 am
My engine likes to start to cut out when I take right turns. I'm thinking its an electrical issue. Any thoughts to the AE86 owners of the world?
a bimmer driver once told me that my 4ag looked like a loaf of bread.
rollacpe
Re: Another 4AG Problem
Postby rollacpe » Wed May 14, 2014 10:53 am
Is it a GTS or a SR5 converted to GTS?
If it is an SR5/GTS conversion, and the GTS tank and fuel lines were not swapped over, you are likely running an un-baffled fuel tank. When you initiate a "hard" right turn on 1/4ish tank, all of your fuel is sloshing away from the fuel pump pick up, thus the cutting out...
If you indeed have a true GTS this may not be the case.
Hope this helps.
knockoutcold
Postby knockoutcold » Wed May 14, 2014 8:14 pm
thanks man, ill keep that in mind. Havnt got around to the fuel pump just yet. i read supra fuel pumps are pretty good as far as performance and affordability go.
rollacpe
Postby rollacpe » Thu May 15, 2014 10:17 am
If it is the fuel tank causing your problems you will find the same issue happening with the supra pump.
saiGone
Postby saiGone » Thu May 15, 2014 2:04 pm
rollacpe wrote:Is it a GTS or a SR5 converted to GTS?
Hope this helps.
All kouki tanks from mid 86 - 87 have the baffle, regardless SR5 or GTS. Only one way to find out if yours does!
Time to drop the tank and have a look.
knockoutcold
Postby knockoutcold » Thu May 15, 2014 8:16 pm
sounds about right. im prolly going to just get a custom tank and install it in my trunk.
allencr
Postby allencr » Thu May 15, 2014 11:24 pm
Is it or is it not cured when there is more then 1/4 tank?
An unnecessarily larger pump will do ZERO for performance and may even create a problem.
knockoutcold
Postby knockoutcold » Fri May 16, 2014 12:46 am
the amount of fuel doesn't matter. actually, turning right tends to cut the engine completely but if the engine has been on for a while or its hot, the engine starts to sputter.
rollacpe
Postby rollacpe » Fri May 16, 2014 6:32 am
I would def still check the tank as there might be something wrong with your pick up on your pump, but it does seem strange that the level of fuel does not matter. I would start at the tank though, not too difficult to drop and check. Keep us posted, and good luck.
knockoutcold
Postby knockoutcold » Sat May 17, 2014 4:03 pm
I mos def will keep posted. thanks for the advice gentlemen!
Users browsing this forum: No registered users and 8 guests
