Electrical inquiry: Is my ammeter broken?
Posted: Thu Jan 17, 2013 2:20 pm
So I picked up an ammeter made for a 1973 celica to run in sequence with the battery and the alternator, but I wonder if the ammeter I bought is even working?
the gauge reads from top to bottom: 50, 0, -50
In instructions i found for other ammeters, it states to see if it's working by running the headlights and the fan to see if there's an amperage draw. I did such and found that the ammeter only dips by a hair, on the scale of 0 to -50, I would say it's only -1 or -2 (amps).
I started the car and the action of kicking the starter in makes the needle jump a little. up and down in a jerking motion +5 to -5 until the car starts. then it's a steady +5 (amps) at idle. If i hit the power windows, it goes up by a hair, +6 or +7 amps. If I turn on the headlights and the fan (whilst idling at +5 amps), i can barely see how high the gauge goes up, but it does go up, like half a hair, maybe to +6 amps then goes back down to +5 amps. On the scale of 0-50, 5 amps looks very very small, the needle looks like it's very close to zero.
when I drive, the ammeter goes up by a hair, like to +6 or +7, but often goes back down to +5.
I have not yet run something electrical for more than 2 or 3 minutes with the engine off to see if the needle dips more, but i may.
so query: are these the normal workings of an ammeter?
R
R
