FAQ FOR GENERAL TECH... ***Read This***
Posted: Tue Apr 22, 2014 1:23 am
by jondee86
DIY / GUIDE - These are topics that help you to fix stuff yourself
TECHNICAL - These are topics that explain how things work
REFERENCE - Reference data, specifications and manuals
DISCUSSION - People comparing notes, ideas and opinions
DISCLAIMER: The following information is provided for your entertainment
and enlightenment. Working on cars is potentially dangerous, and if you are
not confident in your own ability to repair or modify your car safely, you should
have the work carried out by a qualified professional. Club4AG accepts no
liability for damage, consequential or otherwise, to you, your car, or any person
as a result of using the information provided herein - use at your own risk.
DIY GUIDES AND TUTORIALS
AE101 or AE111 20v 4AGE into AE86 Chassis - DIY by Barry
AE86 SR-5 to GT-S Swap - DIY by assassin10000
Replace your leaking pinion seal ON CAR -DIY with pics by HASportAE86
20V Into AE86 - Comprehensive Guide- DIY by Morgan
4AGZE into AE86 Comprehensive Guide - DIY by shubert_ae102
Project Car Magazine SR5 to GT-S Conversion - GUIDE
SUPRA-CELICA Rear End into AE86 - DIY / TECH by assassin10000
T-50 Transmission Rebuild - DIY by assassin10000
AE86 OEM LSD Rebuild - DIY by T3 and assassin10000
E-brake Adjustment for GT-S Rear Axle - DIY by assassin10000
AE86 16V - How to KEEP A/C after P/S DELETE - DIY by negrizio
4AGE 16V - Distributor Rebuild - DIY by Matrix Garage
4AGE 16V - How to adjust the TPS - DIY by Matrix Garage
ARP HEAD STUDS vs Bluetop Distributor Nose! - DIY
ARP HEAD STUDS Oil Clearance FIX - DIY by Matrix Garage
4AGE 16V EGR DELETE, If emissions don't bother you! - DIY/DISCUSSION
20V BT to GTS WIRING TIPS - DIY by HASportAE86
20V VALVE SEALS Replacement - DIY by Morgan
STEERING RACK - P/S to Manual Swap - DIY / TIPS
ELECTRIC FAN Conversion - DIY by Migs
HEATSOAK KILLING YOUR STARTER, Get a wrap! - DIY
AE86 16V - Installing Distributor - DIY
AE86 16V - How to set ignition timing - DIY
INNER TIE RODS How to Change Them - DIY
AE86 IGNITION BARREL How to Remove - DIY by TWIN CAM STATUS
ADJUSTABLE FPR Build Your Own - DIY by oldeskewltoy
AE86 - How to set PINION ANGLE - DIY by assassin10000
AE86 16V - Diagnostic Plug and FP Test Plug - DIY by jondee86
HEAD BOLTS - What tool for removing ? - DIY by gotzoom
Repair Sender for LOW FUEL Warning Light - DIY by aeu86.org
Repair sender for FUEL GAUGE by saiGone
4AGE 16V Distributor Oil Seal Replacement - DIY by assassin10000
TECHNICAL INFORMATION AND GUIDES
OIL PUMP - Shimming for More Pressure - TECH / DISCUSSION by gzus13
ARP ENGINE BOLTS, Torque/lube specifications - TECH by ichibandan
CAMSHAFT Break-In Procedure - DISCUSSION
AE86 16V - Diagnostic Mode Explained - TECH
AE86 16V - Alternator Wiring Basics - TECH
AE86 16V - Starter Motor Basics - TECH
AE86 16V - Auxiliary Air Valve - TECH
AE86 16V - TVIS System - TECH
AE86 16V - Throttlebody - TECH
AE86 16V - Cylinder head Height & Chamber Volume - TECH
AE86 16V - Fuel Pressure Regulator - TECH
AE86 16V - Engine Cooling System - TECH
AE86 16V - Radiator Expansion Tank - TECH
AE86 16V - Cold Start Injector System - TECH
AE86 16V - PISTONS and RINGS - DISCUSSION by Rogue-AE95
4AGZE SC12 SUPERCHARGER Overhaul Guide - TECH by matrix garage
AE86 - Introduction to SPRINGS - TECH
AE86 - Avoiding problems with SPRINGS
AE86 - Shocks (dampers) Part 1 - TECH
AE86 - Shocks (dampers) Part 2 - TECH
AE86 - Shocks (dampers) Part 3 - TECH
How a BRAKE MASTER CYLINDER Works - TECH
BT20V VVTi TRANSISTOR and Bogging Issue - TECH / DISCUSSION by HASportAE86
20V ST LEAKING CAPACITORS in ECU - TECH by jondee86
HOW TO BREAK IN A REBUILT ENGINE - TECH by mototuneusa.com
AE86 - TRACTION BRACKETS - How they Work - TECH
REFERENCE MATERIAL, TECH SPECS, MANUALS
FSM, Factory Service Manuals, Where to get! - REFERENCE by AEU86.org
Lifting the Lid on the mk1 MR2 ECU Part 2 - REFERENCE by Jeremy Ross
AE86 16V - Diagnosis Codes - REFERENCE
AUTOSHOP 101, Toyota Tech Info! - REFERENCE by Autoshop101.com
SUPRA-CELICA LSD and DIFF Rebuild -TUTORIAL by Zuk
AE86 - Convert Front Struts to COILOVERS - TUTORIAL - by Club4AG
4AGE FREEZE PLUG Sizes - REFERENCE
Electrical Fault Finding 01 - VOLTAGE DROP Testing
Electrical Fault Finding 02 - CONTINUITY Testing
Electrical Fault Finding 03 - DRY JOINT in Soldered Connections
Inside the TVIS MANIFOLD - REFERENCE by aw11mr2
MY-ACOUSTIC Huge Amount of 4AGE / KE70 Data - REFERENCE
DISCUSSION, IDEAS AND OPINIONS
What LSD for my AE86 - DISCUSSION
AE86 - PINION ANGLE - DISCUSSION
AE86 - Damper Choice for 8/6kg/mm Swift Springs - DISCUSSION
TRACTION BRACKETS and FOUR LINKS - DISCUSSION
STEERING RACK - AE86 P/S to AW11 Manual Conversion - DISCUSSION
20V BT BELT TENSIONER Conversion - DISCUSSION
16V HEAD BOLTS - How to Torque them - DISCUSSION
What's all the fuss about COP's ? - DISCUSSION by jondee86
LIGHT FLYWHEELS for 16v - DISCUSSION
ROD BOLTS - Can I Re-use Them ? - DISCUSSION
If you would like to nominate others for listing here, feel free to
post a link in this thread and I will add them in.
Re: FAQ FOR GENERAL TECH... ***Read This***
Posted: Thu May 29, 2014 4:11 pm
by jondee86
Thanks to ZINCHOTRAN for a great find :)
Levin/Trueno Tuning Part 1 Engine assembly
https://www.youtube.com/watch?v=QS3h1Vrw50I
Levin/Trueno Tuning Part 1 continued Head assembly
https://www.youtube.com/watch?v=dYp5zYvFd1A
Levin/Trueno Tuning Part 2 Clutch - LSD - gearbox
https://www.youtube.com/watch?v=UZEXzbDpqoY
Bear in mind that these guys know what they are doing and
make it look very easy. But regardless, if you are planning to
do any of this work on your car, well worth a watch.
Posted: Sat Sep 27, 2014 9:58 am
by tchybrid
woohooo! awesome work there Jondee!
Posted: Mon Oct 20, 2014 8:50 am
by saiGone
Great round up!
Posted: Wed Jan 07, 2015 10:19 am
by Grant
Finally a sticky post! :)
Posted: Wed Jan 07, 2015 11:27 am
by PDB
Whoohoo :) all the info at the top, jondee86 is going to have so much spare time now
Posted: Sat Jan 10, 2015 9:54 pm
by ZINCHOTRAN
Assassin10000's LSD rebuild thread: very quick & dirty.
http://forums.club4ag.com/zerothread?id=13062
Nod yo head & butta yo bread. What a interesting site.
http://www.my-acoustic.com/Car/rear_axl ... ebuilt.htm
Posted: Mon Jan 12, 2015 2:45 pm
by jondee86
ZINCHOTRAN wrote:Assassin10000's LSD rebuild thread
Added this as a good reference thread now that the Weir rebuild
seems to have disappeared from the web.
http://www.my-acoustic.com/Car/rear_axle/LSD_Rebuilt/LSD_Rebuilt.htm
Yes, this site is an interesting read, and I have visited it many times :)
A story of one man's learning process with his car and the 4AGE. There
are so many sections that it is hard to decide what to link up. I'll have
another browse and put up a couple of links... good suggestion.
Posted: Tue Jan 13, 2015 8:17 pm
by ZINCHOTRAN
We all get to this point and want to feel like a new owner of an older, sexy automobile.
http://www.aeu86.org/forum/showthread.php?pid=151308
Posted: Wed Jan 14, 2015 7:14 pm
by jondee86
Good find... just need the gauge sender DIY fix now :)
Posted: Thu Jan 15, 2015 2:08 pm
by saiGone
jondee86 wrote:Good find... just need the gauge sender DIY fix now :)
Fuel guage sender DIY? I linked one a few months back
viewtopic.php?f=28&t=14153
Posted: Thu Jan 15, 2015 6:17 pm
by jondee86
Must have missed that one, but it's in the FAQ now :)
Funny enough, my gauge doesn't go much over halfway even
with a full to the brim tank. So this is one of the jobs on my
list of things to do.
Posted: Thu Jan 22, 2015 12:35 am
by jondee86
Just came across this... not a bad read. In fact I would go so far as to say that
anyone starting out on an AE86 project and wanting to know about suspension,
should make this the first thing they read
SUPER STREET - Project Toyota Corolla AE86 Part 1
Having fun on a budget.
SUPER STREET - Project Toyota Corolla AE86 Part 2
Shocking new developments.
SUPER STREET - Project Toyota Corolla AE86 Part 3
Suspension mods and power steering conversion.
Posted: Thu Jan 22, 2015 7:52 pm
by ZINCHOTRAN
Necessary to read and learn from others. Quite in depth
Posted: Fri Jan 23, 2015 9:07 am
by Clouds
It's gotten bigger since the last time I looked at this. :o
**mod edit**
Posted: Mon Feb 09, 2015 8:22 am
by IndiaDorifto7
Thanks man! This is great stuff! :D :D :D
Posted: Mon Feb 09, 2015 9:25 am
by Clouds
One day, this thread will have the answers to the universe alongside information on every Toyota ever. :lol:
Posted: Sat Dec 12, 2015 3:21 am
by totta crolla
Here is an interesting repair article on Idle air control valve:
http://www.mr2.com/forums/threads/10453 ... adjustment
Posted: Sun Dec 13, 2015 5:13 pm
by jondee86
totta crolla wrote:Here is an interesting repair article on Idle air control valve.
I saw a thread once before when someone pulled the valve apart and
discovered the "adjustable" plate. They also had a bit of difficulty in
getting the plate to move !!
I'm sure it is possible for the wax filled actuator to lose a bit of range
over the years, but I have not experienced this myself. What I have
experienced is the failure of the valve to close because of a blockage
in the water circuit. And this is by far the most common cause of the
hot idle being high. The remedy is simply to clear the blockage so that
water circulates freely thru the valve, and all will be good.
AFAIK the valve is factory set to give a cold idle of 2200rpm (actuator
retracted). So I am not clear on how you can get a cold idle of 2500rpm
unless the idle air bypass screw is wound out, or there is some other
problem happening at the same time. Point being, that this kind of
repair should be a last resort after all other possible causes have been
investigated and eliminated.
Thanks for the contribution... keep them coming :)
Posted: Thu Nov 17, 2016 2:12 pm
by Moto-P
You're awesome!
Posted: Mon May 29, 2017 12:03 pm
by grappletech
None of the links work anymore :(
Posted: Mon May 29, 2017 8:59 pm
by jondee86
Yes, any links that went to stuff posted on the old forums are not working.
The old forum went down about six weeks ago about the time the login script
got changed. I emailed Moto about it over a month ago, but nothing has been
done. His PM is not working, but I'll try another email.
