Ae86 roll cage
Posted: Wed Jan 16, 2013 8:22 pm
by MarkDaFunkyHomosapien
I'm interested in buying a roll cage for my 85 Corolla GTS. Found these online and am wondering what the difference between these two. I see the description but one is 250 and the the other seems to be about a grand. Thanks in advance.
Re: Ae86 roll cage
Posted: Sun Jan 20, 2013 4:51 pm
by T.C
The top link are ready to install bolt in cages with good material. On the bottom link you would want the choice with DOM tubing and that one is 500 and would still need to be welded together
Re: Ae86 roll cage
Posted: Mon Jan 21, 2013 10:29 am
Thanks buddy. I emailed Enjuku but I don't think I'll get a reply
Re: Ae86 roll cage
Posted: Fri Jan 25, 2013 12:27 am
by Illegal_Garage
Find a local fabricator and get a cage built to your needs
Max
Re: Ae86 roll cage
Posted: Fri Jan 25, 2013 3:59 am
by Red
FWIW, if you are buying a cage I'm assuming that is for track use. Check with the governing authority for the events that you pan to run in, to make sure the cage meets their specs. They're not all the same, and finding out you've got the wrong cage after it is done could ruin the day.
