Help
kiwi
Help
Postby kiwi » Sat Mar 29, 2014 12:26 pm
Hello,
After a couple of years, I have finally got my pieced together GTS at the point of attempting start up. Everything came from everywhere; not two things came together. I'm familiar with jap map versions, but no so much with these. Tried to start it. I have spark, timing looks good, wants to fire, but doesn't. Looking for some great advice for where to start checking. All help truly appreciated.
Kiwi
Re: Help
Postby jondee86 » Sat Mar 29, 2014 1:52 pm
Does the cold start injector squirt while cranking ?
kiwi
Re: Help
Postby kiwi » Sat Mar 29, 2014 2:34 pm
Thanks for the advice. Just pull the cold start and watch for spray? My harness like many other things came from elsewhere; is there a good USDM Zenki wiring diagram available online? I'm sure my injector wires are probably out of sync, and I bet a couple of the plugs are in the wrong places for things like TVIS, cold start, etc.
Kiwi
Re: Help
Postby jondee86 » Sat Mar 29, 2014 3:08 pm
Yes... pull the injector out and stick the end in a bottle and crank.
Wiring diagram here...
http://files.aeu86.org/manuals/ewd-ae86-1986-usdm-parrot.pdf
