what transmission to use
Ok so I am buying a smallport 4age going to bore 20 over get a brian crower 1.8 stroker kit. 10:1 82mm pistons is what im choosing and the pro rods. Then i am getting kelford 193t cams, aem ems4 ecu, completely rewiring it, getting new water pump, oil pump and completely rebuilding it. getting adjustable cam gears, hks timing belt, different alt ac and power steering pulleys. see through cam gear cover and then getting a gt2860rs turbo..my question is what transmission is best for this. I currently have a c52 and the ratios are nice for quick spool but final drive ratio sucks. at 100mph im over 5k rpm. please help
- onelungderryl
Re: what transmission to use
You're leaving something out... what is this whole engine setup going in? I'm going to have to make a guess that you have some sort of fwd corolla due to the mention of the c52 and power steering.
Making this post in one of the tech sections would probably yield better results.
"Working on cars is not what I do... it's who I am." Steve Metcalf
