Alternator bad??
86love
Alternator bad??
Postby 86love » Fri Feb 21, 2014 1:19 pm
Recently my charge/ebrake light doesn't come on when you turn the key before starting, check engine light's on, and then when started the charge/ebrake light's do come on while running, my guess is alternator is going bad :x
Re: Alternator bad??
Postby MisterJerk » Fri Feb 21, 2014 2:14 pm
or its unplugged.
86love
Postby 86love » Fri Feb 21, 2014 4:28 pm
It's not unplugged lol, i'm sure of that. I'm thinking the alternator took a shiet.
Postby jondee86 » Fri Feb 21, 2014 10:35 pm
Check the "engine" and the "Charge" fuses in the under hood fuse box.
Check the alternator belt is properly tensioned.
aukword1
Postby aukword1 » Sat Feb 22, 2014 12:20 pm
you can always pull the positive terminal off the battery when the car is running to test to see if the alternator is working...if the car stays running, its good, if not then the alternator is bad...
86love
Postby 86love » Sat Feb 22, 2014 6:54 pm
Well, actually today just recently on my way home, the charge light was not on, then down the road, light's slowly dimmed out, could barely see the road, charge light and ebrake light came on, car was missing through out changing gears, so it's obvious it's the alt. I turned around in the middle of the road, parked it back at my buddy's house and cut it off, tried starting it, nothing. Picking one up tommorow probably, and take mine is to test it.
Nick94tt
Postby Nick94tt » Sun Feb 23, 2014 7:04 am
86love wrote:Well, actually today just recently on my way home, the charge light was not on, then down the road, light's slowly dimmed out, could barely see the road, charge light and ebrake light came on, car was missing through out changing gears, so it's obvious it's the alt. I turned around in the middle of the road, parked it back at my buddy's house and cut it off, tried starting it, nothing. Picking one up tommorow probably, and take mine is to test it.
More or less word for word what happened to a MK2 MR2 I had a long while back. Alternator died. Always worth checking the cheap and easy fixes first though. Hope the replacement alt does it for you. Now would be a logical time to replace accessory belts if yours are worn as well.
meifert
Postby meifert » Mon Feb 24, 2014 8:41 am
aukword1 wrote:you can always pull the positive terminal off the battery when the car is running to test to see if the alternator is working...if the car stays running, its good, if not then the alternator is bad...
That is actually not a good thing to do. It can cause a power surge through the electrical system and kill the alternator or other electrical components. The battery acts as a buffer from surges.
86love
Postby 86love » Sat Mar 01, 2014 3:51 pm
Well, I've got a new alternator. All problems solved! It finally died on me coming home one evening, felt the motor missing and struggling, light's dimmed out, i turned around and had to park it back at my buddy's house. But with this said, there is one problem that drives me insane... Every time I decelerate and let off my gas pedal, a relay click's and it has to be the main circuit? I'm guessing? But it does it.. every.. single.. time. Everyday. One solid click, as soon as I let off the gas, It did it when I got the car and has done it for over a year! I've checked all ground's, even came down to finding one bad one from the intake to the firewall, fixed it. I'm clueless..
ra40
Postby ra40 » Sat Mar 01, 2014 6:12 pm
glad you figured it out. another way to check is just using a voltmeter on the battery itself to see how much voltage was being put out. my corolla would do the same it would light up the ebrake light and battery light when the alternator went bad. its normal
86love
Postby 86love » Sat Mar 01, 2014 9:40 pm
Yea man I understand that, I know that's normal. Appreciate it though. But i'm just clueless on when I decelerate, I believe the main circuit relay click's as I let off the gas, one sold click. everytime. It's a relay, but i'm just taking a guess at the main circuit.
Postby MisterJerk » Mon Mar 03, 2014 7:44 am
sounds like the COR, that controls fuel pump. Check codes. Also a AFM being at a downward angle if your idle is low, it closes, turning off the fuel pump.
ZINCHOTRAN
Postby ZINCHOTRAN » Tue Mar 11, 2014 8:18 am
There are two 'alternator brushes' inside. Replace those and clean up the sleeve. That's what I did and haven't had a problem since. The brushes were a few dollars. Cheap but easy to fix. Don't forget a soldering iron.
