aceforever wrote:Weird noise coming from cylinder on firewall. What is that thing?
That cylinder appears to be the "Charcoal Cannister" that is used on the USDM
AE86 as part of the emissions control system. It´s task is to absorb gasoline fumes
venting from the gas tank while the engine is not running. The cannister incorporates
an air inlet (underneath I think?) with a one-way valve. There is a small outlet on
top that connects to a vacuum source on the inlet side of the engine... I´m not
sure exactly where.
When the engine starts, air is drawn in thru the one-way valve, thru the charcoal
picking up some of the absorbed fumes, and they get drawn into the engine intake
manifold and burned.
I also don't have the FPR hooked up to fuel, could it be that?
The FPR maintains (controls) pressure between the outlet of the pump and the
inlet of the FPR. On the outlet of the FPR the pressure drops to close to atmospheric
in the return line to the tank. The FPR is pressure compensated by a small hose that
senses vacuum in the intake manifold. The idea is to maintain a constant pressure
differential across the fuel injectors by reducing the rail pressure as the manifold
pressure drops.
Looking at this picture it looks like the FPR goes to a 23265 "Filter". That looks a
lot like the 3 hole plug on the Tank Vacuum Box. Is that right?
Yes. As you no longer have an inlet plenum to provide a vacuum signal for the FPR
the signal is taken from the vacuum box. In due course you will find that the ITB´s
do not generate a very strong vacuum signal, so the calibration of the FPR will be
incorrect. This is not a problem, as you can compensate for the difference in your
fuel map on the ECU.
