The TRD sets were/are known as TRD5 (the one that changes all but 4th) and TRD3 (1st, 2nd and 3rd).
TRD5 was clearly made for the racetrack. First is super tall (55MPH in a 4.3) and the rest get progressively closer until 4th to 5th is even shorter than stock! (I wouldn't fit the shorter 5th).
Besides the "clutch killer" 1st, the jump from 3rd to 4th so short, it'd only makes sense if you got very poor torque to increase speed easier/faster at higher gears.
Tsuchiya used to run this set when his car was prepped by TRD/Sakurai-san, coupled with a 5.375 ring and pinion, which made the car super quick to accelerate once you got going (don't forget that tall 1st).
TRD3 seems to be more aimed at rallying, and is just a tad taller 1-3, but pretty similar to OEM in "spirit". The gap from 3rd to 4th is long enough that now, Tsuchiya uses this on his Tec-Arts tuned car (with a 4.77), and they have fitted a "3.5" (a ratio shorter than fourth, but it goes where the 5th used to be), in order to make a proper spacing and shorter, closer ratios. Not a fan of this "cheap" solution that many Japanese use in their racing 86. It makes me confused where the gear is going to go, and makes me too aware of over revving the engine in a miscalculated downshift.
Then, as Jondee said, there are tons of other brands, but I'm not that sure the proper R&D has gone into them. Or at least, buying it from a reputable brand like Cusco, gives me more peace of mind.
Cusco offered a type A which was only a 3.5 gear. I never found a reference for the type B, but type C basically makes the spacing between 1st through 4th very even, which allows for a very good all-round solution. Type D is also available, but is a bit more extreme version of the TRD5 set. Yes, 1st is even taller(!!).
Here's a video I put together when I was comparing my favorite options: the TRD5 with a 4.77, to make taking off from traffic lights less hard) and the Cusco Type C (stock 4.3).
It was the Cusco I was sold on, since I wanted to keep the 4.3 for now and, using the car on the street, I didn't want to replace clutches every other week with that tall 1st... Let alone taking off at a "normal" pace from the traffic lights, not waiting for the engine to reach higher revs in order to make any sort of pace.
https://youtu.be/2we5ejX427gSent from my iPhone using Tapatalk
