Postby b-rock » Sun Nov 30, 2014 12:55 am
You should research further -- but as far as I can remember, only OE Toyota LSDs use axles that are 6 or 8mm shorter (?? exactly?). I'm pretty sure that TRD LSDs don't need shorter axles. Hopefully someone will chime in. Aftermarket LSDs definitely don't need shorter...
Your second diff pictured isn't an open diff like the caption says -- it's a TRD. Your axles will work if they're Kouki/Kouki.
The first LSD looks like an ancient Cusco (that are totally different from the newer ones -- and you can't get parts anymore)... I'd love to see inside that Cusco to see if has RS plates or the earlier ones you can't get.... Crack it open! It's a 1-way.
Test the preloads on them to see what shape they're in.... Both the bearing preload and the LSD preload... Squirt a bunch of diff oil into the LSD guts and work it in before you (or someone) measures the LSD preload... You can learn a lot before you stick it in a car or rebuild it... There is no sense using it if the preloads are way off. That Cusco one has a bit of a rusty ring gear... Hopefully not pitted.
There should be a number stamped on the side of the ring gear -- probably 4.3... ??
