Possible to convert SR5 rear axles to use disc brakes?
- Rogue-AE95
I've searched around the net trying to see if this has been done before, but I can't find anything. I suppose drum brakes aren't all that bad, but I'd prefer the easier maintenance of rear discs... but it's not like I will find a GT-S rear end very easily. So I'm wondering if anyone has ever kept their SR5 rear end, but converted it to use disc brakes. Would GT-S axle shafts with their disc brakes fit into the SR5 housing and diff? Is it possible to fit disc rotors onto the drum axle shafts? I'm thinking this would require custom fab work to get the calipers & brackets in place. I'm willing to try.
For the record, I have an '88 Corolla All-Trac, the rear end (supposedly) being basically the same rear as the AE86 SR5's (and perhaps the Tercel 4WD's).
Re: Possible to convert SR5 rear axles to use disc brakes?
IF your rear end is the same as an AE86 SR5 rear end, YES. Go to hawkmachine.com you need different bearing retainers and caliper brackets from them, cheap. You'll be able to use Wilwood Dynamite calipers and Mitsubishi Galant rear rotors. Mess with the brake lines a little and hammer down.
Knockoff Crew member #0001
Buy the last issue of 86Garage magazine, it tells you how to do this
My turd of an 86
20v swapped 86 write-up
My turd of an 86
- Rogue-AE95
I suppose the only problem I may have is that the All-Trac's lugs are 4x100. AE86 has 4x114. Hmm... at least there is hope and a starting point. I'm not worried about rims because I could pick up a set of aftermarket rims that have both 4x100 and 4x114 patterns.
morgan wrote:Buy the last issue of 86Garage magazine, it tells you how to do this
Thanks... had a look at their site. Do you mean the May 2012 issue? Says something about an SR5 disc rear end on the front cover.
That be the one. Sr5 rear converted with disk brakes
My turd of an 86
My turd of an 86
- Rogue-AE95
I just tried to buy it but it's sold out. Augh!
Remind me next week to scan it. PM me your email.
My turd of an 86
My turd of an 86
You can't use GT-S axles in your rear end, they are larger. You're using your axles. I also believe in Japan there was a rare option of disc brakes with the small SR5 rear end.
pearls ain't free
^close, but in japan the base model 86 had an sr5 drum rear with an lsd.
sorry for the delay guys, i keep forgetting to scan the pages and post. wrote myself a note to hopefully remember today.
My turd of an 86
My turd of an 86
I would be more interested in getting an LSD into the SR5 rear end. Pretty sure it was asked a lot on the old board.
- Rogue-AE95
morgan wrote:sorry for the delay guys, i keep forgetting to scan the pages and post. wrote myself a note to hopefully remember today.
No worries, take your time. I'm pretty far off from actually working on this. Doing my research for now. I still need to read up on suspension and what I want to do (front = AE92, rear = AE86).
BlackStar wrote:I would be more interested in getting an LSD into the SR5 rear end. Pretty sure it was asked a lot on the old board.
I'm wondering if the AE95 rear diff is an LSD or not. I mean it is AWD, wouldn't that be like LSD? More stuff I don't know about AWD / 4WD and things like LSDs. Although I thought SR5 guys could fit the GT-S LSD into the rear. I'm getting confused about the nature of my AE95's rear end now... I thought it could take the GT-S LSD because they're the same size rear.
well im glad i bought a bunch of copies of that issue before it was sold out, thats me on the cover!
emails of scanned pages in PDF format sent to you two.
morgan
morgan
My turd of an 86
My turd of an 86
- Rogue-AE95
Thanks Morgan! I still have some questions even after reading the article, but I'll re-read it a few more times before posting them here. One thing is that I thought Wilwood made 4-piston calipers which could take e-brake cables as well as the hydro lines. Hmmm.
And I'm thinking that the best thing to do once the 14mm spacers are finalized is to weld them to the brackets. I'm curious if the aluminum will hold up to use & abuse?
+1 that mag has the complete swap in it
yup, but my issues sold out Sean. you know if Jonas is making another printing of the Out Of Stock issues?
My turd of an 86
My turd of an 86
no I havent heard anything other then he has his hands full with these mags lol
- Rogue-AE95
morgan wrote:yup, but my issues sold out Sean. you know if Jonas is making another printing of the Out Of Stock issues?
If he did, I would still buy the magazine out of respect for having printed the article. I'm loving that there are options out there for those of us unlucky enough to have factory drum brakes. I'm just hoping I can make this work for an AE95, and maybe use those Wilwood calipers that have both hydraulic and cable brake capability. I'm sure my friend can help me fab something up if those Hawk parts won't work for me... but the hawk stuff is a great launching point.
I'll email Jonas and see...
My turd of an 86
My turd of an 86
Imtrevorurnot
Would the same parts apply to the JDM AE86 GT-V with an LSD?
Does anyone still have this pdf. I'm looking to do the swap on my SR5
rumsawatti
Isnt it cheaper and easier to just buy/find a GTS rear end then to do this conversion?
So I just tried to buy myself a copy, and as many others have stated, it's sold out. Could someone out there message me the PDF for this? I'd love to do a GTS swap, but finding one locally has produced more headaches than success. I figure it may just be easier to do the swap on my SR5 rear. I was planning on running a spool regardless of rear end, but man...drum breaks hurt my feelings.
Stop by my place, take pics or borrow a copy
My turd of an 86
My turd of an 86
morgan wrote:Stop by my place, take pics or borrow a copy
Thanks for the offer, man. I'll take you up on this for sure!
jetmanblack
Hey guys, I know this is a bit of an old thread, but can someone send me a copy of the article about the brake conversion? I have an sr5 that I'd like to swap the drums for disks too.
- Rogue-AE95
A year later, and I'm only at the parts-acquisition stage. I decided not to do the Wilwood calipers. The calipers with cable parking brakes are expensive. I thought about adapting AE92 Corolla GT-S rear calipers and discs to my AE95, but used parts go for too much. I'd be better off buying new / reman parts for not much more cost. I can't find AE92 GT-Ss anywhere around me in junkyards.
Well, I found an '88 MR2 in the junkyard recently. I pulled the rear calipers, and today I got my rear rotors. I only need one more parking brake cable and some other bits and pieces. I won't be able to do this conversion anytime soon, but at least I will have all my parts gathered up.
Hey guys,
Would anyone have a pdf file to share of that how-to swap? I'm just getting underway on a monster build w/ my wagon.
Rogue-AE95 wrote:A year later, and I'm only at the parts-acquisition stage. I decided not to do the Wilwood calipers. The calipers with cable parking brakes are expensive. I thought about adapting AE92 Corolla GT-S rear calipers and discs to my AE95, but used parts go for too much. I'd be better off buying new / reman parts for not much more cost. I can't find AE92 GT-Ss anywhere around me in junkyards.
I'm very curious as to if you got the MR2 parts to work.
1984 Toyota Corolla Sport SR5
1989 Ford Bronco Eddie Bauer
1968 Ford F250
Lots of 4AC info here: http://4ac-powered.forumotion.com/
1968 Ford F250
jetmanblack
Any news on this conversion?
I am trying to do the same here in Okinawa. I have done some research and have seen write ups saying that the Toyota Surf and Nissan Primera rear ends are the same size and will work. I understand these models are not the same in the US but maybe they have a different name?
