4A-GE 16v Alternators Interchangeable..??
El Gato Felix
My 4A-GE 16v RWD alternator stopped charging
. Will an alternator from an (AW11) Mr2 4A-GE or later generation Corolla (AE92) 4A-GE bolt up with no issues..?? Also would it connect into my existing alternator plug in..?? Tried the SEARCH button but no luck again. Thanks
Re: 4A-GE 16v Alternators Interchangeable..??
Most r interchangeable. Some mr2's work n others the brackets are flipped tge opposite way. Most of the plugs from that time period are all the same aswell. I am using or trying to use a mk3 supra alt wich is a 70a the same as the mr2. It is spot on w the 86 alternator except the plug n post r slighty clocked in a diff position. They are also priced the same at most local part stores to the 86 units
El Gato Felix
^^^ Thanks for the reply
Is the alternator from a 7M-GTE or a 7M-GE..?? Sounds like it would be a great upgrade especially with more amps
Im currently using one off a AE92. It works fine and all the connections are correct. Just be aware that it is possible that aftermarket AE86 4age alternator pullies will not fit with a new model alternator.
7mge alt.= 70Amps
7mgte alt.= 80Amps
Swap over ae86 pulley.
There's lots of write up about this is you need more info,
Hope it helps
7mgte alt.= 80Amps
Hope it helps
Depending on what brand of alternator you have the stator shaft diameter may change. So you may not be able to just bolt on your pulley. I have had this happen to me. So try to stay with toyota and rebuild what you have.
Ijust purchased an MKIII supra alt on ebay. Its a high output of 130A. When i receive it, ill update
ANYONE CAN BUY A NEW CAR. IT TAKES A TRUE ENTHUSIAST
TO BREATHE LIFE INTO AN OLDER ONE.
El Gato Felix
Good info here!! Thanks everyone!! =)
I had an alternator from an aw11 on my last 86 worked great. I would like to swap my new alternator with a 7mgt in the near future due to extra stuff I will be adding to the car.
